Civil Engineering Association eBooks Structural Books Concrete Evaluation of Minimum Longitudinal Reinforcement Requirements for Reinforced Concret
 ptqc06
User ID: 1131
Threads: 14
Likes: 183 in 15 posts
Given Likes: 101
06-15-2011, 11:59 AM (This post was last modified: 06-15-2011, 06:49 PM by oanm2000.)
Evaluation of Minimum Longitudinal Reinforcement Requirements for Reinforced Concrete Columns
Size: 2.3 MB | Format: PDF
[Image: 63855076592266312671.png]
Existing minimum longitudinal reinforcement requirements for columns were developed to prevent passive yielding of reinforcement resulting from creep deformations in the concrete. Tests used to support this limit were conducted decades ago when steel yield strengths for reinforcing bars were approximately half of what is common today. The design of a very large percentage of columns in TxDOT bridges is typically controlled by minimum eccentricity of loads, implying a substantial reduction in column steel and resulting economic savings might be possible with present-day materials.
DIRECT LINKS thumbup
[-] The following 21 users Like ptqc06's post:21 users Like ptqc06's post
  â€¢ Dell_Brett, techno, malc, kowheng, oanm2000, seriousboy, ivanveliki, robertsas, Jackass, tluc, jf28, cristi, sasan7351, cesar3226, Trishu999, Clouseau, Nilupa, ruaumoko, Mannish, salahcivil, blaze
  Reinforcement Detailing Handbook for Reinforced and Prestressed Concrete carolinandra 0 1,895 01-29-2022, 08:01 PM
Last Post: carolinandra
  Fiber-Reinforced Polymer: Reinforcement for Concrete Structures abudabeeja 1 3,020 05-21-2019, 06:35 AM
  Non-Destructive Evaluation of Reinforced Concrete Structures: vol 1 & 2 ir_71 4 4,226 04-16-2018, 01:30 PM
Last Post: scorpion07
  Minimum Reinforcement in Concrete Members abudabeeja 4 5,525 10-21-2016, 03:01 PM
  Evaluation of Longitudinal Joint Tie Bar System mahyarov 0 1,575 11-17-2012, 12:55 PM
Last Post: mahyarov
  Flexural and Tensile Properties of Thin, Very High-Strength, Fiber-Reinforced Concret mahyarov 0 1,615 11-13-2012, 09:06 AM
Last Post: mahyarov
  Glass Fiber Reinforced Polymer Dowel Bar Evaluation mahyarov 0 1,488 11-10-2012, 07:22 AM
Last Post: mahyarov
