Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 14411:2006 Ceramic tiles — Definitions, classification, characteristics and mar
05-30-2011, 12:20 PM
BS EN 14411:2006 Ceramic tiles - Definitions, classification, characteristics and marking
Author: CEN/TC 67 “Ceramic tiles” | Size: 1 MB | Format: PDF | Publisher: CEN | Year: 2006 | pages: 70
[Image: 48419363926601951100.jpg]
This European Standard defines and gives terms, specifies requirements and marking criteria for ceramic tiles (produced by extrusion and dry-pressing techniques) of the best commercial quality (first quality). Tiles not of first commercial quality are also covered following the provisions of Annex Q. This European Standard does not cover tiles made by other than the normal processes of extrusion or drypressing nor decorative accessories or trim (such as edges, corners, skirting, capping, coves, beads, steps, curved tiles and other accessory pieces) or mosaics (i.e. any piece that can fit into a 7 cm × 7 cm area, see custom nomenclature).
NOTE EN ISO 10545 describes the test procedures required to determine the product characteristics listed in this European Standard. EN ISO 10545 is divided into parts, each describing a specific test procedure or related matter.
  • kowheng, st77bel, toa011, utan, peixoto, sivlad, Rami11
Threads: 57
05-11-2019, 08:38 AM
Size: 1.04 MB | Format: PDF
[-] The following 5 users Like kowheng's post:5 users Like kowheng's post
  • PinkPant, Dell_Brett, Nita1391, oanm2000, Rami11
  BS EN 491:2011 Concrete roofing tiles and fittings for roof covering and wall claddin mybest 1 2,326 06-23-2016, 10:08 AM
Last Post: PinkPant
  BS EN 12859:2011 Gypsum blocks - Definitions, requirements and test methods ir_71 3 3,287 12-27-2014, 10:34 PM
Last Post: Veggeta
  BS EN 490:2011 Concrete roofing tiles and fittings for roof covering and wall claddin mybest 0 1,757 03-14-2012, 12:32 PM
Last Post: mybest
  BS EN 12808 Grouts for tiles hich 1 2,198 12-10-2011, 05:28 PM
  BS EN 15221-1:2006 Facility management. Terms and definitions mybest 0 1,733 11-30-2011, 03:46 PM
Last Post: mybest
