Civil Engineering Association eBooks Water & Hydraulic Engineering Groundwater Recharge from Run-off, Infiltration and Percolation
 ska51
User ID: 11535
Threads: 382
Likes: 9,406 in 1,251 posts
Given Likes: 4017
05-30-2011, 11:28 AM
Author: K.-P. Seiler and J.R. Gat | Size: 5.0 MB | Format: PDF | Publisher: Springer; 1st edition | Year: 2007 | pages: 244 | ISBN: ISBN: 1402053053
[Image: 08200609857869789088.jpg]
Book Description:
Groundwater constitute the most important reservoir of available clean water. Due to its overexploitation, some anthropogenic mismanagement on the surface and the overloading of the cleanup potential of subsurface, many of the groundwater systems used for water supply are in jeopardy. The problem is very severe in dry-lands, but also in urban, industrial, agricultural and traffic areas.
This book first discusses the recharge fluxes relating both to the quantity and quality of groundwater. In order to face the threats to the water supply and to be able to maintain a sustainable water management policy, detailed knowledge is needed in between others on the surface to subsurface transformation link in the water cycle. Secondly, the presentation and comparison of both the traditional and modern approach to determine groundwater recharge is discussed. The traditional approach to determine groundwater recharge, is based on water balance estimates and hydraulic considerations, which yield instantaneous values at best but do not integrate the totality of recharge pathways in time and space. In contrast, environmental tracers do integrate these factors. Finally, the fate of groundwater recharge in the subsurface by hydraulic and geologic means is discussed in detail, in order to stimulate adapted groundwater management strategies and to better assess consequences of climate changes on groundwater resources as a whole.
Audience
This book will be of interest to hydrologists, hydro-geologists, engineers, geographers, agronomists, soil scientists, groundwater modellers, environmental physicists, limnologists
"Downstream is Weaker"
[-] The following 8 users Like ska51's post:8 users Like ska51's post
  â€¢ pedzaquino, kowheng, OSHO, toa011, malc, Evandrojr, hanung, cepot
 ska51
User ID: 11535
Threads: 382
Given Likes: 4017
12-13-2011, 06:45 PM
Mirrors:
Password for last three links:
[-] The following 2 users Like ska51's post:2 users Like ska51's post
  â€¢ kaci, lokillo11
 lokillo11
User ID: 12383
Threads: 2
Likes: 36 in 7 posts
Given Likes: 86
06-12-2012, 06:55 AM (This post was last modified: 06-12-2012, 07:23 AM by 3fan.)
Groundwater Recharge from Run-off, Infiltration and Percolation (Water Science and Technology Library)
Author: K.-P. Seiler, J.R. Gat | Size: 15 MB | Format: PDF | Quality: Unspecified | Publisher: Springer; Softcover reprint of hardcover 1st ed. 2007 edition (November 29, 2010) | Year: November 29, 2010 | pages: 260 pages | ISBN: 9048173337
[Image: 54435787206865945196.jpg]
To face the threats to the water supply and to maintain sustainable water management policies, detailed knowledge is needed on the surface-to-subsurface transformation link in the water cycle. Recharge flux is covered in this book as well as many other groundwater issues, including a comparison of the traditional and modern approaches to determine groundwater recharge. The authors also explain in detail the fate of groundwater recharge in the subsurface by hydraulic and geologic means, in order to stimulate adapted groundwater-management strategies.
[-] The following 8 users Like lokillo11's post:8 users Like lokillo11's post
  â€¢ kowheng, 3fan, malc, zrilek, david-smith, mahyarov, Dell_Brett, milova
  Groundwater Geophysics: A Tool for Hydrogeology By Groundwater Geophysics abudabeeja 4 3,823 08-26-2014, 05:53 PM
Last Post: r3be1
  Estimating Groundwater Recharge ska51 1 2,228 11-26-2012, 07:53 PM
Last Post: ska51
  Ground Water Recharge Using Waters of Impaired Quality ska51 0 1,611 01-12-2012, 03:38 PM
Last Post: ska51
  Water Management: Conservation, Harvesting and Artificial Recharge ska51 0 1,492 01-12-2012, 02:12 PM
Last Post: ska51
