Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Shear capacity of masonry walls externally strengthened
[Request] Shear capacity of masonry walls externally strengthened
 medo_sk
Macedonia
User ID: 18907
Threads: 39
Likes: 108 in 43 posts
Given Likes: 63
04-25-2011, 11:11 PM
HI Civileans,
If anyone has a copy, please share it.
C. Faellaa, E. Martinellia, E.o Nigrob and S. Pacielloa, "Shear capacity of masonry walls externally strengthened by a cement-based composite material: An experimental campaign", Construction and Building Materials, Volume 24, Issue 1, January 2010, Pages 84-93.
 melkat
User ID: 1901
Threads: 77
Likes: 3,565 in 324 posts
Given Likes: 1623
04-25-2011, 11:39 PM
[-] The following 5 users Like melkat's post:5 users Like melkat's post
  • malc, Dell_Brett, medo_sk, Grunf, zrilek
  [REQUEST] Cyclic Performance of Concrete-Backed Stone Masonry Walls abouferass88 1 1,896 04-18-2016, 04:29 PM
Last Post: ssobhan
  [REQUEST] Reinforced Concrete Shear Walls With Openings; Test and Analysis cosminupt 1 2,084 04-23-2014, 04:29 PM
Last Post: Mohammad6299
  [REQUEST] Diagonally reinforced coupling beams of shear walls andre85 0 1,632 03-25-2014, 03:15 PM
Last Post: andre85
  [REQUEST] BS EN 1745:2012 Masonry and masonry products. Methods for determining thermal propert ir_71 0 1,445 08-20-2013, 03:02 PM
  [REQUEST] Shear strength of masonry walls DamirDz 0 1,628 01-15-2013, 07:49 PM
Last Post: DamirDz
  [REQUEST] Predicting the In-plane Capacity of Masonry Infilled Frames tachauhan 1 2,012 12-30-2012, 07:50 PM
Last Post: hich
  [REQUEST] A Simplified MCFT for Shear Capacity Scaling of R/C Beams AlmostThere 1 1,916 11-06-2012, 01:09 PM
