Civil Engineering Association eBooks Structural Books Steel SCI P313: Single storey steel framed buildings in fire boundary conditions
Threads: 1,298
04-25-2011, 04:55 AM
Author: W I Simms, G M Newman | Size: 1.08 MB | Format: PDF | Publisher: SCI | Year: 2002 | pages: 86 | ISBN: 1859421350
[Image: 38922916904769543259.jpg]
Building regulations require that external walls of single storey buildings that are close to the site boundaries should have fire resistance, to at least part of the walls. Any structure that provides support to such walls also has to have fire resistance. This publication provides, in addition to UK building regulations, design recommendations and guidance for single storey buildings for design in fire situations. Based on earlier research and study, it shows that fire protection to the roof structure, which would be expensive to provide, is not necessary, provided that recommendations on column base design are followed. The advice and recommendations cover single and multi-bay portal frames, monopitch portal frames, gable frames and frames with trussed roofs. The background to the recommendations is given and the mathematical models are explained.
  • kowheng, malc, blaze, seriousboy, jcbv, vvvv, toa011, oanm2000, zrilek, jferrer, sodapas, monter, visu, gulilero, bigone
Threads: 54
11-15-2012, 04:12 PM (This post was last modified: 11-16-2012, 12:13 AM by Dell_Brett.)
all links dead;
Post Edited by Moderator
  • Jackass, gulilero, Trishu999, warbeast, bigone
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 3,219 01-10-2023, 12:16 AM
Last Post: carolinandra
  Australia Steel Ins Design example for multistorey composite steel framed building leong8929 2 3,551 01-18-2020, 05:45 PM
Last Post: monter
  AISC Design Guide 35 Steel-Framed Storm Shelters sabooryan 0 1,871 09-05-2019, 06:08 PM
Last Post: sabooryan
  SCI: Fire safe design - A new approach to multi-storey steel framed buildings dinu69in 2 3,051 03-17-2018, 11:03 AM
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 1,997 05-13-2016, 12:35 PM
Last Post: Dobblo
  Designing Steel Structures for Fire Safety lamkin 4 4,315 01-13-2016, 01:14 AM
Last Post: ibg0203
  Fire Design of Steel Structures, ECCS Bmartin 3 3,652 11-10-2015, 02:39 AM
Last Post: ibg0203
