Civil Engineering Association Software Software Product Autodesk Products Autodesk Quantity Takeoff 2012
Threads: 1,118
04-17-2011, 09:36 PM (This post was last modified: 04-18-2011, 03:12 AM by BennyP.)
[Image: 62427954487214654046.gif]
[Image: 22276500972585767678.gif]
Autodesk Quantity Takeoff: Building material cost estimate software. Cost Estimating & Quantity Surveying Software. Autodesk® Quantity Takeoff building cost estimating software helps make material costing faster, easier, and more accurate. Cost estimators can create synchronized, comprehensive project views that combine important information from building information modeling (BIM) tools such as Revit® Architecture, Revit® Structure, and Revit® MEP software together with geometry, images, and data from other tools. Automatically or manually measure areas and count building components, export to Microsoft® Excel®, and publish to DWF™ format.
Features:
* Takeoff in minutes automatically—Perform a takeoff on an entire building information model (BIM) in just minutes through integration of 2D and 3D design data.
* Greater flexibility than typical databases or spreadsheets—Perform interactive examination of 3D models for material cost estimating purposes.
* Dynamic counting—Count and quantify design data quickly and easily.
* More efficient manual takeoff—Supports the takeoff of JPG, TIF, PDF, and other “nonintelligent” image formats.
* Share, query, and clarify—Generate quantities linked to specific objects. Mark up and “round-trip” your comments.
* Faster and more insightful quantity reports—Create summaries and detailed quantity surveying reports quickly and easily.
Installed in Windows 7 64 bit. This is a 32 bit applications and need the use of X-Force KG 32 bit. You cannot install if your Regional Settings (Format and Location in W7) are not one of included in EULA (received an error). I used Canada and English (Canada).
[-] The following 18 users Like BennyP's post:18 users Like BennyP's post
  • dquan373, jfjdm, engr1900, Grunf, Dell_Brett, adamsawi, blaze, yutt, stldtls, vccalderon, snakes, zrilek, sasan7351, salahcivil, DamaD, piyush86, drewpt, uetian19
Threads: 1,118
04-18-2011, 03:06 AM
Other links:
[-] The following 8 users Like BennyP's post:8 users Like BennyP's post
  • Grunf, dquan373, cheo.smith, yutt, snakes, zrilek, malc, uetian19
 reza2001
User ID: 31835
Likes: 2 in 1 posts
Given Likes: 0
04-19-2011, 04:57 PM (This post was last modified: 04-19-2011, 06:18 PM by BennyP.)
Autodesk AutoCAD Quantity Takeoff V2012 x86-ISO | 1.63 GB
[-] The following 2 users Like reza2001's post:2 users Like reza2001's post
  • zrilek, cadmon
 niki102
User ID: 8143
Threads: 82
Likes: 2,495 in 189 posts
Given Likes: 845
04-21-2011, 03:43 AM
[Torrent File Link]
Download Size : 644.61 MB
[-] The following 5 users Like niki102's post:5 users Like niki102's post
  • vccalderon, zrilek, albani, henrycv, uetian19
  Autodesk Products 2012 x-force keygen for x32 systems BennyP 7 18,760 03-07-2025, 10:37 AM
  Autodesk AutoCAD Plant3D 2012 (x86/x64) BennyP 6 11,641 01-17-2013, 05:47 PM
  Autodesk AutoCAD LT 2012 x32 x64 ISO BennyP 12 20,661 12-17-2012, 03:32 PM
  Autodesk Quantity Takeoff 2013 BennyP 4 8,573 09-16-2012, 02:31 PM
Last Post: Mohammad6299
  Autodesk Subscription 2012 MegaPack BennyP 9 17,537 03-18-2012, 08:36 PM
Last Post: oasis_tree
  Autodesk AutoCAD Structural Detailing 2012 x32 x64 BennyP 18 32,724 03-01-2012, 02:19 PM
  Autodesk Inventor Standard and Professional 2012 (x86 x64) BennyP 10 16,891 02-24-2012, 07:05 PM
