Civil Engineering Association eBooks Journals, Papers and Presentations The Effect Measured of the Rubber Membrane on the Triaxial Compression Strength
 tynhanh
Vietnam
User ID: 19721
Threads: 58
Likes: 202 in 42 posts
Given Likes: 227
04-15-2011, 08:14 AM (This post was last modified: 04-15-2011, 08:29 AM by Grunf.)
The Effect Measured of the Rubber Membrane on the Triaxial Compression Strength of Clay Samples
Authors: D. J. Henkel; G. D. Gilbert
Source: Géotechnique, Volume 3, Issue 1, pages 20 –29 , ISSN: 0016-8505, E-ISSN: 1751-7656
Size: 702 KB | Format: PDF
Here it is:
[Image: comments.png]
Good luck!
TY
[-] The following 6 users Like tynhanh's post:6 users Like tynhanh's post
  • Grunf, kowheng, Dell_Brett, oanm2000, melkat, peymanlord
  Size Effect on Shear Strength of Deep Beams: Investigating with Strut-and-Tie Model asim99 0 4,510 05-27-2013, 08:44 PM
  Measured performance of a 26 m deep top-down excavation in downtown Shanghai asim99 0 4,419 05-14-2013, 03:10 PM
  Detection and assessment of damage in 2D structures using measured modal response arshiakh 0 3,799 04-24-2013, 07:03 PM
Last Post: arshiakh
  Optimized Sections for High-Strength Concrete Bridge Girders—Effect of Deck Concrete ir_71 1 6,382 03-02-2013, 05:08 AM
Last Post: arshiakh
  The Effect of Weathering on the Shear Strength Properties of Keuper Marl mybest 0 3,814 03-18-2012, 02:43 PM
Last Post: mybest
  Size effect of concrete in compression, State-of-the–Art ir_71 0 4,788 12-08-2010, 02:07 PM
