Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Thesis 2009 - Investigating composite behavior of Geosynthetic reinforced soil mass
 kundanili
User ID: 28863
Threads: 4
Likes: 110 in 11 posts
Given Likes: 61
04-13-2011, 02:50 PM (This post was last modified: 04-13-2011, 03:24 PM by kundanili.)
Thang Quyet Pham (Ph.D., Civil Engineering) “Investigating Composite Behavior of Geosynthetic-Reinforced Soil (GRS) Mass” Colorado US. 2009
ABSTRACT A study was undertaken to investigate the composite behavior of a Geosynthetic Reinforced Soil (GRS) mass. Many studies have been conducted on the behavior of GRS structures; however, the interactive behavior between the soil and geosynthetic reinforcement in a GRS mass has not been fully elucidated. Current design methods consider the reinforcement in a GRS structure as “tiebacks” and adopt a design concept the reinforcement strength, Tf, and reinforcement spacing, Sv, have the same effects on the performance of a GRS structure. This has encouraged the designers to use stronger reinforcement at larger spacing, as the use of larger spacing will generally reduce time and effort in construction. A series of large-size Generic Soil-Geosynthetic Composite (GSGC) tests were designed and conducted in the course of this study to examine the behavior of GRS mass under well-controlled conditions. The tests clearly demonstrated that reinforcement spacing has a much stronger effect on the performance of GRS mass than reinforcement strength. An analytical model was established to describe the relative contribution of reinforcement strength and reinforcement spacing. Based on the analytical model, equations for calculating the apparent cohesion of a GRS composite, the ultimate load carrying capacity of a reinforced.....
File expiration date: permanently April 20, 2011
Mirror
[-] The following 15 users Like kundanili's post:15 users Like kundanili's post
  • sumiscute, blaze, 3fan, civilteam, gameon, tluc, nhim4mat2006, miquan, kaci, IzzyCole, TurboXUser, cristi, fordcell, cigutierrezg, Nilupa
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
12-09-2011, 11:14 PM
[Image: password.png].
[-] The following 3 users Like 3fan's post:3 users Like 3fan's post
  • Dell_Brett, serhioSPA, peymanlord
  Ground Improvement and Reinforced Soil Structures: Proceedings of Indian Geotechnical poolmand 0 1,723 08-02-2021, 06:36 AM
  Performance of Reinforced Soil Structures - by McGown, K.C.Yeo, K.Z.Andrews mojmax 4 4,302 12-13-2019, 01:38 PM
  Reinforced Soil Engineering, Advanced in Research and Practice babak 11 7,623 12-08-2015, 06:08 PM
Last Post: ibg0203
  Soil Stress-Strain Behavior: Measurement, Modeling and Analysis hich 3 3,363 10-23-2015, 02:45 PM
Last Post: PinkPant
  Recommendations for Design and Analysis of Earth Structures using Geosynthetic Reinfo ziggywas1 1 2,759 09-26-2013, 11:23 PM
Last Post: ssobhan
  Soil Behavior and Geo-Micromechanics hich 0 1,665 12-01-2012, 08:53 AM
Last Post: hich
  PERFORMANCE OF GEOSYNTHETIC-REINFORCED WALLS SUPPORTING THE FOUNDERS/MEADOWS BRIDGE A mahyarov 0 1,573 11-12-2012, 09:05 PM
Last Post: mahyarov
