03-31-2011, 06:31 AM
AS 1012.16-1996 Methods of testing concrete - Determination of creep of concrete cylinders in compression
Author: Committee BD-042 | Size: 5.8 MB | Format: PDF | Publisher: Standards Australia | Year: 1996 | pages: 7 | ISBN: 0733707270
![[Image: 31803333726089250196.jpg]](https://pic.civilea.com/images/31803333726089250196.jpg)
This Standard describes the procedure for determining the creep of standard concrete test cylinders subjected to a sustained longitudinal compressive load. This method does not provide means for calculating time-dependent deflection of reinforced or prestressed concrete members.
NOTE: The conditions for curing and storage (see Clause 6) can be varied to suit different requirements, e.g. early pre-stress. The time of loading (see Clause 7) can also be varied to give an indication of other properties. These variations, however, will not comply with the requirements for a creep test as specified in this Standard.
