Civil Engineering Association eBooks Structural Books Steel SCI P247: Over-cladding of Existing Buildings using Light Steel
Threads: 1,298
03-31-2011, 04:47 AM (This post was last modified: 03-31-2011, 04:53 AM by ir_71.)
Author: R M Lawson, R Pedreschi, I Falkenfleth, S O Popo-Ola | Size: 2.4 MB | Format: PDF | Publisher: SCI | Year: 1993 | pages: 60 | ISBN: 1859420842
[Image: 48030726470795726444.jpg]
Buildings are commonly over-clad to improve their appearance, to increase thermal insulation, and to reduce maintenance costs. This publication reviews the use of light steel construction in the over-cladding of existing concrete and masonry buildings as part of a renovation process. The over-cladding systems use sub-frame members that are connected to the existing structure or cladding. The new facade is attached directly to the subframe members. The sub-frame members are assembled from galvanized cold formed steel components, and a variety of different cladding materials may be used. The design aspects for over-cladding systems are reviewed, and the use of steel in over-cladding is discussed. A series of Case Studies from Belgium, Canada, Denmark, Finland, Germany and the United Kingdom are presented to show the range of applications of light steel in over-cladding. A prototype steel intensive over-cladding system is described, and interim results from the testing of this system are reported. It is demonstrated that in most cases the cost of the over-cladding will be re-couped within a 20 year period, if all the potential savings are considered.
[-] The following 21 users Like ir_71's post:21 users Like ir_71's post
  • hmwere, kowheng, jcbv, malc, dizz, ting tsai huang, blaze, vvvv, toa011, Clouseau, jferrer, ikoleci, zrilek, nuttapolk, knrsa, Nilupa, baikur, Adam Smith, kmmh76, Jackass, bigone
Threads: 54
11-15-2012, 02:00 PM
all links dead; direct link
  • isurya, Dell_Brett, bigone
Threads: 54
11-15-2012, 03:22 PM
another link
word
this and the above post can be joined by our moderators
  • gulilero, Jackass, Trishu999, bigone
 r3be1
San Marino
User ID: 424
Threads: 47
Likes: 2,809 in 355 posts
Given Likes: 101
10-29-2014, 04:39 PM
[-] The following 18 users Like r3be1's post:18 users Like r3be1's post
  • zrilek, dinu69in, eliseo.as, malc, Dell_Brett, ibg0203, knrsa, avge, PinkPant, jcbv, Jackass, oanm2000, subin91, milova, draluka, bridgeengineer, chenamoy, harsono
  SCI P301: Building Design using Cold Formed Steel Sections: Light Steel Framing in Re ir_71 2 3,468 11-13-2014, 08:42 AM
Last Post: concreteok
  SCI - Durability of Light Steel Framing in Residential Building joradu 3 3,304 08-24-2014, 08:33 AM
Last Post: pram
  SCI P272 Modular Construction using light steel framing: An Architect's Guide bigone 1 2,052 01-10-2014, 08:08 PM
Last Post: arshiakh
  SSMA Product Technical Catalog (Light Gauge/Cold-Formed Steel) goober 3 3,554 11-16-2012, 07:41 AM
  SCI: Best Practice for the Specification and Installation of Metal Cladding ir_71 2 2,572 11-15-2012, 03:29 PM
  SCI - Appraisal of existing Iron and steel structures gboyega 1 2,382 06-10-2012, 11:50 AM
  Modification of Existing Welded Steel Moment Frame Connections for Seismic Resistance we_mbm 0 1,711 02-07-2012, 02:00 PM
Last Post: we_mbm
