Civil Engineering Association Software Software Product Autodesk Products Autodesk Simulation Mechanical 2012
Threads: 1,118
03-30-2011, 04:16 AM (This post was last modified: 03-30-2011, 06:12 PM by BennyP.)
Autodesk Simulation Mechanical 2012 x32 x64 ISZ | 1.6 GB
Autodesk Simulation provides a large set of engineering analysis tools, which enables designers and engineers already in the initial stage of the design cycle mechanism, site, or the details get close to exact product specifications. And along with it - to improve design, increase reliability, reduce time and cost of production, as well as to facilitate interaction between the different actors involved in product design.
The following types of engineering analysis can be performed:
- static stress and fatigue strength;
- the dynamic loads in the linear region of deformation of materials;
- natural frequencies (modal analysis);
- range of reactions;
- fixed and random vibration;
- stability analysis;
- Shock;
- contact analysis;
- Stationary and time-varying heat transfer and heat transfer;
- steady and unsteady flow;
- Flow in porous media;
- Flow in open channels;
- Mass transfer;
- electrostatics.
Installed in Windows 7 64 bit. Use 669D1 for code.
[Image: 59785929979121734815.gif]
Torrent link:
RAR Password: FromCivilEA
  â€¢ niki102, jcbv, seriousboy, sasan7351, ha893459, jose19356
 niki102
User ID: 8143
Threads: 82
Likes: 2,495 in 189 posts
Given Likes: 845
03-30-2011, 04:56 AM (This post was last modified: 03-30-2011, 05:09 AM by niki102.)
Autodesk Simulation Mechanical 2012 x32 / x64 1GB*x Links
1.68 GB
1 GiG Links
  â€¢
Threads: 1,118
03-30-2011, 07:27 PM
Other links:
  â€¢ Grunf, jose19356
  Autodesk Products 2012 x-force keygen for x32 systems BennyP 7 18,840 03-07-2025, 10:37 AM
  Autodesk AutoCAD Mechanical 2022 (x64) Pre-Cracked BennyP 0 5,296 03-29-2021, 05:23 AM
  Autodesk AutoCAD Mechanical 2019 BennyP 0 4,065 04-01-2018, 05:22 AM
  AUTODESK AUTOCAD MECHANICAL V2016 WIN32/WIN64-ISO BennyP 1 5,856 03-20-2015, 02:52 PM
  Autodesk Autocad Mechanical 2016 (x64 + x32) Trial BennyP 0 4,805 03-13-2015, 09:54 AM
  Autodesk AutoCAD Mechanical 2015 BennyP 1 5,660 03-20-2014, 09:41 AM
  Autodesk Simulation CFD 2013 (x86/x64) Mohammad6299 4 10,297 09-12-2013, 04:52 AM
Last Post: Mohammad6299
