Civil Engineering Association eBooks Structural Books Steel Eurobuild in Steel - Comparison of the Design of a Portal Frame
Threads: 1,298
Likes: 25,490 in 1,924 posts
03-05-2011, 03:44 PM
Size: 4.41 MB | Format: PDF | Year: 2006 | pages: 98
[Image: 04423574194308643383.jpg]
The typical structure of a single-storey hall in most countries in Europe is the portal frame. This document provides a comparison of the calculation methods acc. to Eurocode 3 (EN 1993-1-1) and the national standard of the respective country. The calculation is performed for a typical portal frame structure in Europe. The frame uses hot rolled I-sections of steel grade S235 for the rafter and columns. Frame span is 30m and eaves height 5m, which are typical dimensions for small and medium sized industrial halls in Europe. Haunches are used for the eaves by providing additional hot-rolled sections welded onto the bottom flange of the rafter. The eaves connection as well as the apex is typically bolted and assumed rigid for this example, so that effects of rotations in the connections do not have to be taken into account. Column bases are pinned as no increased horizontal stiffness, e.g. for cranes, has to be provided.
[-] The following 32 users Like ir_71's post:32 users Like ir_71's post
  • kowheng, fashion, melkat, Dell_Brett, blaze, oreslaw, ssi3k, jcbv, Mohoh77, cordoba123, jferrer, giga, toa011, zainseiya, kg85arun, zrilek, robertsas, seriousboy, Grunf, manoj, monter, mastermind, Nilupa, baikur, kmmh76, slowet, vvvv, lisine, hmwere, ykhackhack, gulilero, cristi
Threads: 54
11-22-2012, 05:50 AM
all links dead; mirror
password
[-] The following 21 users Like andersen3's post:21 users Like andersen3's post
  • warbeast, lednar_ved, stanislove, blaze, Dell_Brett, vvvv, subin91, Jackass, Trishu999, hmwere, malc, ykhackhack, gulilero, yanburak, stigtg, we_mbm, eng donny, cace-01, PinkPant, Pinkto, simanta
  Structural Fire Design to EC3 & EC4, comparison to BS5950 choonguan 2 2,908 05-10-2021, 03:44 PM
  Example in portal frame from A to Z mowafi3m 2 3,023 05-31-2018, 10:43 AM
Last Post: malee
  Steel Frame Design Examples febo927 1 2,024 05-28-2018, 01:57 PM
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 1,895 05-13-2016, 12:35 PM
Last Post: Dobblo
  Steel frame design - lecture bashir999 3 4,258 11-13-2014, 02:10 AM
Last Post: stlooi
  Advanced Analysis in Steel Frame Design - Guidelines for Direct Second-Order Inelasti asim99 1 2,285 07-07-2014, 03:08 AM
Last Post: i_kabir
  SCI P164: Design of Steel Portal Frames for Europe robertsas 3 4,514 02-17-2014, 08:42 AM
Last Post: vinnunsam
