Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Stud Welding of Shear Connectors on Steel Bridges
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1668
02-21-2011, 08:55 PM
[Image: 52069434406476793054.jpg]
The construction of Cooper River Bridge is used as an example to illustrate the use of headed shear connector studs, the stud welding equipment and drawn-arc process in relation to the various designs and practices currently being used in composite construction of bridges. Full depth prefabricated precast deck panels with rebar loops are interlocked with studs and comply with seismic design specifications. Topics include anchoring precast bridge deck panels using shear connectors, panel designs, welding beams on barges, surface preparation, weld inspection, accessories, layout, and procedures. This paper serves as a practical guide and reference source of welding shear connector studs in construction of steel bridges, and the use of shear connectors to connect steel beams to factory produced precast concrete deck slabs with rebar loops.
523KB, 13 pages
[-] The following 16 users Like mowafi3m's post:16 users Like mowafi3m's post
  β€’ blaze, Dell_Brett, malc, melkat, usman, kowheng, oanm2000, zrilek, monter, tremonti, ha893459, ting tsai huang, davegabj, jokerβ„’, lesgiu, harsono
  Design of Modern Steel Railway bridges melkat 3 5,679 02-06-2019, 04:29 AM
  The Design of Modern Steel Bridges by Sukhen Chatterjee Flexi 8 6,927 10-08-2018, 04:54 PM
Last Post: febo927
  Prestressed Steel Bridges, Theory and Design toa011 3 4,686 08-19-2018, 10:01 AM
Last Post: Kurucz
  Design and Construction of Modern Steel Railway Bridges asim99 0 2,011 08-18-2017, 11:04 PM
  Seismic Design and Assessment of Bridges: Inelastic Methods of Analysis and Case Stud asim99 1 1,836 03-09-2017, 03:36 PM
  Steel Bridges - Conceptual and Structural Design of Steel and Steel-Concrete Composit ssobhan 5 4,809 09-23-2015, 06:06 AM
Last Post: hodzicemir
  Fatigue Life of Riveted Steel Bridges lamkin 5 4,247 08-14-2014, 08:05 PM
Last Post: r3be1
