Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 13391:2004 Mechanical tests for post-tensioning systems
02-20-2011, 01:18 PM (This post was last modified: 03-14-2013, 02:42 PM by mybest.)
Author: CEN/TC 250 | Size: 1.25 MB | Format: PDF | Publisher: CEN | Year: 2004 | pages: 21
[Image: 08922497689896988871.jpg]
This European Standard specifies the test procedures for the anchorages and couplings of post-tensioning systems. This standard is to be used in conjunction with the relevant European Standards ENV 1992-1-1 andENV 1992-2 and others for pertaining to prestressed concrete structures.The test results should be used for the acquisition of the Technical Approval of the specified post-tensioningsystem.For unbonded tendons additional tests and requirements are needed and these are not covered in the presentscope of this standard.
  â€¢ kowheng, blaze, melkat, usman, zrilek, toa011, Adam Smith, oanm2000, almadar12, peixoto
Threads: 49
03-14-2013, 02:00 PM
all links dead; reposted here:
password:
  â€¢ Dell_Brett, blaze, subin91, peixoto, st77bel, chenamoy
  BS EN 1097-2:2010 Tests for mechanical and physical properties of aggregates. Methods ir_71 1 2,368 07-21-2017, 04:39 PM
  BS EN 1097-10:2002 Tests for mechanical and physical properties of aggregates. Determ ir_71 0 1,915 08-20-2012, 02:43 PM
  BS EN 1097-5:2008 Tests for mechanical and physical properties of aggregates. Determi ir_71 0 1,647 08-20-2012, 02:37 PM
