Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills
02-19-2011, 07:35 PM (This post was last modified: 02-20-2011, 12:26 AM by Dell_Brett.)
BS 8006-1995 + A1 Code of practice for Strengthened/reinforced soils and other fills
Author: Technical Committee B/526 | Size: 3.51 MB | Format: PDF | Publisher: BSI | Year: 1995 | pages: 206 | ISBN: 0580242161
[Image: 57812182903546476354.jpg]
This British Standard contains guidelines and recommendations for the application of reinforcement techniques to soils, as fill or in situ, and to other fills. The standard is written in a limit state format and guidelines are provided of safety margins in terms of partial material factors and load factors for various applications and design lives.The code is divided into nine sections. Section1 identifies the scope, definitions and notation of the code. Section 2 describes the concepts and fundamental principles of reinforced soil. Section 3 provides recommendations for the use of materials where existing standards are available. Where materials are used which are not covered by existing standards or where known materials are to be used in ways not covered by existing standards section 4 gives recommendations for the testing and approval of such materials.Sections 5 to 9 relate to design, construction and maintenance of walls and abutments, slopes and foundations. They include specific recommendations for characterization of the soils to be used and other factors affecting the design and performance of the structures. Emphasis is placed on quality control both with regard to the consistency of the properties of the fill and reinforcing materials and to the handling of the materials on site.Much of the existing practice of reinforced soil is based on the use of limit equilibrium design methods which incorporate a global factor of safety. In keeping with the principles of limit state design, consistent structural dimensions and materials quantities have been maintained with existing practice by calibration of the partial factors in the limit state design relationships in this code. This approach is different to that adopted by some concurrent codes of practice, e.g. BS8002:1994, which rely on the use of β€œworst credible” parameters to develop an adequate margin of safety.The clauses are supplemented by a substantial list of references to enable the user to consider in greater depth the applications of the technique.
[-] The following 21 users Like ir_71's post:21 users Like ir_71's post
  β€’ melkat, oanm2000, usman, 2824, Gabemzaman, Dell_Brett, Adam Smith, uvsrao61, kowheng, Hengki, malc, toa011, cason, Rainbow, dbsimon29, cace-01, isurya, zrilek, Svetoslav, peixoto, asim99
 melkat
User ID: 1901
Threads: 77
Likes: 3,565 in 324 posts
Given Likes: 1623
05-10-2011, 04:03 AM (This post was last modified: 11-28-2011, 01:11 PM by Dell_Brett.)
BS 8006-1:2010 Code of practice for strengthened/reinforced soils and other fills
Author: - | Size: 18 MB | Format: PDF | Publisher: BSI | Year: 2010 | pages: 260 | ISBN: 978 0 580 53842 1
[Image: 80153550869513186881.jpg]
The use of reinforcement in soils has become an accepted technique for the construction of retaining walls, steep slopes and basal strengthening. This code of practice has been revised and updated to include information about new methods of soil reinforcement and to bring the document in line with BS EN 1997-1:2004 , NA to EN 1997-1:2004 and BS EN 14475:2006 .
Reinforced soil techniques are now used extensively for a range of design lives and service requirements and are still in an active stage of development, particularly as far as the use of polymeric materials is concerned.
This code of practice embodies the experience of engineers successfully engaged on the design and construction of the particular class of works.
Contents of BS 8006-1:
Foreword
Section 1: General
Section 2: Concepts and fundamental principles
Section 3: Materials
Section 4: Testing for design purposes
Section 5: Principles of design
Section 6: Walls and abutments
Section 7: Reinforced slopes
Section 8: Design of embankments with reinforced soil foundations on poor ground
Annexes
Annex A (normative) Assessment of partial material factors for reinforcements
Annex B (normative) Projects for the Highways Agency, Scottish Executive, The National Assembly for Wales and The Department for Regional Development Northern Ireland
Annex C (informative) Propping forces
Annex D (normative) Site damage test
Annex E (normative) Design of base slabs supporting vehicle parapets for highways
Annex F (informative) Design of reinforced soil structures for earthquake resistance
Bibliography
[-] The following 18 users Like melkat's post:18 users Like melkat's post
  β€’ Rainbow, ir_71, blaze, jcbv, malc, Trishu999, ebaturalp, Dell_Brett, utan, st77bel, cigutierrezg, cace-01, ruaumoko, didie, zrilek, jcaz15, nhim4mat2006, toa011
 hich
User ID: 3732
Threads: 94
Likes: 5,003 in 418 posts
Given Likes: 101
07-04-2011, 09:15 PM (This post was last modified: 11-28-2011, 01:11 PM by Dell_Brett.)
Mirror:
[-] The following 26 users Like hich's post:26 users Like hich's post
  β€’ avscorreia, Dell_Brett, Adam Smith, kowheng, st77bel, techno, handresy, ir_71, blaze, ziggywas1, Grunf, zrilek, peixoto, isurya, oanm2000, cordoba123, 2824, malc, kevin8107, Trishu999, jcaz15, sivlad, vvvv, Jackass, ting tsai huang, nhim4mat2006
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
11-28-2011, 10:46 AM (This post was last modified: 11-28-2011, 01:08 PM by Dell_Brett.)
Mirror link
18 MB
[-] The following 14 users Like mybest's post:14 users Like mybest's post
  β€’ Jackass, Dell_Brett, warbeast, lasalleguy, jcbv, zrilek, nhim4mat2006, peixoto, dbsimon29, toa011, desertrat, pousin, Hengki, lisine
Threads: 154
08-22-2012, 06:06 AM
[-] The following 5 users Like shadabg's post:5 users Like shadabg's post
  β€’ slowet, Jackass, Dell_Brett, st77bel, nhim4mat2006
Threads: 49
02-15-2013, 01:06 PM
links dead; reposted here:
pass:
  β€’ ssobhan, Jackass, Dell_Brett, knrsa, peixoto, asim99
 st77bel
Romania
User ID: 12964
Threads: 12
Likes: 432 in 86 posts
Given Likes: 696
08-22-2013, 11:15 AM
New working link:
[-] The following 6 users Like st77bel's post:6 users Like st77bel's post
  β€’ isurya, metrok45, zrilek, nhim4mat2006, hodzicemir, f_slikken
Threads: 49
08-22-2013, 11:21 AM
the password for post #6 is
  β€’ st77bel, Andrew seah, metrok45, zrilek, samplex
Likes: 8,311 in 1,373 posts
Given Likes: 94
05-29-2024, 12:10 PM
BS 8006-1:2010 + A1:2016: Code of practice for strengthened/reinforced soils and other fills
| Size: 73.12 MB| Format: PDF| Quality: Scanner
[Image: 40091174955107577295.jpg]
This post has been made by CivilEA Post-Generator V2.4.3
  β€’ babakfeyzi, fordcell, PinkPant, Umer.Aleem
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,997 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 10,457 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,512 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,801 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,391 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,626 02-17-2021, 11:20 AM
Last Post: temp1366
  BS 7255:2001 Code of practice for Safe working on lifts ir_71 2 3,204 08-09-2019, 10:11 PM
Last Post: Nita1391
