Civil Engineering Association eBooks Journals, Papers and Presentations Freeze-Thaw Resistance of Concrete With Marginal Air Content
02-16-2011, 06:05 AM
Author: Jussara Tanesi and Richard Meininger | Size: 2.02 MB | Format: PDF | Publisher: FHWA | Year: 2006 | pages: 96
[Image: 51043425781597641363.jpg]
Freeze-thaw resistance is a key durability factor for concrete pavements. Recommendations for the air void system parameters are normally: 6 Β± 1 percent total air, and spacing factor less than 0.20 millimeters. However, it was observed that some concretes that did not possess these commonly accepted thresholds presented good freeze-thaw resistance in laboratory studies. This study evaluated the freeze-thaw resistance of several β€œmarginal” air void mixes, with two different types of air-entraining admixtures (AEA)β€”a Vinsol resin and a synthetic admixture. This study used rapid cycles of freezing and thawing in plain water, in the absence of deicing salts. For the specific materials and concrete mixture proportions used in this project, the marginal air mixes (concretes with fresh air contents of 3.5 percent or higher) presented an adequate freeze-thaw performance when Vinsol resin based air-entraining admixture was used. The synthetic admixture used in this study did not show the same good performance as the Vinsol resin admixture.
  β€’ kowheng, cace-01, melkat, Dell_Brett, usman, Umer.Aleem
  NIST: Best Practice Guidelines for Structural Fire Resistance Design of Concrete and ir_71 2 8,061 03-19-2017, 09:43 PM
Last Post: Dell_Brett
  Chloride Resistance of Concrete ir_71 1 5,440 10-11-2012, 11:10 AM
  Superabsorbent Polymers β€” An Additive to Increase the Freeze-Thaw Resistance of ... lisine 0 3,589 08-11-2012, 10:41 AM
  Frost and Scaling Resistance of High-Strength Concrete ir_71 0 3,794 04-18-2011, 04:57 AM
  Abrasion resistance and effect of manufactured sand on concrete mortar datagap 1 5,729 12-16-2010, 06:38 AM
Last Post: Grunf
