Civil Engineering Association eBooks Journals, Papers and Presentations Design of Continuously Reinforced Concrete Pavements Using Glass Fiber Reinforced Pol
02-03-2011, 05:04 AM
Design of Continuously Reinforced Concrete Pavements Using Glass Fiber Reinforced Polymer Rebars
Author: Jeong-Hoon Choi and Roger H. L. Chen, | Size: 1.19 MB | Format: PDF | Publisher: HFWA | Year: 2005 | pages: 81
[Image: 37261340856399458790.jpg]
This is Task 3: Continuously Reinforced Concrete Pavement. The corrosion resistance characteristics of glass fiber reinforced polymer (GFRP) rebars make them a promising substitute for conventional steel reinforcing rebars in continuously reinforced concrete pavements (CRCPs). Studies are conducted on the effect of using GFRP rebars as reinforcement in CRCP on concrete stress development, which is directly related to the concrete crack formation that is inevitable in CRCP. Under restrained conditions, concrete volume change because of shrinkage and temperature variations is known to cause early- age cracks in CRCP. In this study, an analytical model has been developed to simulate the shrinkage and thermal stress distributions in concrete due to the restraint provided by GFRP rebars in comparison with the stresses induced by steel rebars. The results show that the stress level in concrete is reduced with GFRP rebars because of a low Young’s modulus of GFRP. In addition, the analytical model has been used to estimate concrete strain variation in reinforced concrete slabs because of changes in concrete volume, and the results were compared with the experimental observation. Finite element (FE) methods are also developed to predict the stress distribution and crack width in the GFRP-reinforced CRCP section that is subjected to the concrete volume changes under various CRCP design considerations, such as the coefficient of thermal expansion (CTE) of concrete, the friction from the pavement's subbase, and the bond-slip between concrete and reinforcement. Based on the results from the FE simulation along with the mechanistic analysis, a series of feasible designs of the GFRP-reinforced CRCP is proposed. The stress levels in the GFRP reinforcement, the crack widths, and the crack spacings of the proposed pavements are shown to be within the allowable design requirements.
  â€¢ kowheng, usman, cace-01, blaze, Dell_Brett, pedzaquino, roaming79, Grunf
  Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures asim99 1 6,470 04-20-2018, 05:19 PM
Last Post: munycamsec
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 5,139 03-16-2016, 09:41 AM
  Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 9,233 02-10-2016, 02:49 PM
  Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 7,350 07-08-2015, 08:02 AM
Last Post: PinkPant
  BEHAVIOR OF FIBER-REINFORCED POLYMER (FRP) COMPOSITE PILES UNDER VERTICAL LOADS ir_71 1 6,983 06-01-2015, 05:11 PM
  Earthquake Resistant Design of Reinforced Concrete Buildings - Past and Future RyanRS 0 5,726 04-04-2015, 02:50 AM
Last Post: RyanRS
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,290 11-15-2014, 02:07 PM
