Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 2499 Hot-applied joint sealant systems for concrete pavements
01-09-2011, 07:51 AM (This post was last modified: 01-09-2011, 07:56 AM by ir_71.)
Author: Committee B/510 | Size: 1.5 MB | Format: PDF | Publisher: BSI
[Image: 86550493578796562725.jpg]
BS 2499-1:1993
Hot-applied joint sealant systems for concrete pavements. Specification for joint sealants
BS 2499-2:1992
Hot-applied joint sealant systems for concrete pavements. Code of practice for the application and use of joint sealants
BS 2499-3:1993
Hot-applied joint sealant systems for concrete pavements. Methods of test
Author: Committee B/510 | Size: 0.5 MB | Format: PDF | Publisher: BSI
[Image: 28901559532434298122.jpg]
Author: Committee B/510 | Size: 1.6 MB | Format: PDF | Publisher: BSI
[Image: 84376511558846815944.jpg]
  â€¢ vvvv, blaze, Dell_Brett, oanm2000, Grunf, Adam Smith, mrjoesan2, ziggywas1, usman, toa011, fer962933, roaming79, peixoto, asim99
Threads: 49
02-14-2013, 10:50 AM
links dead; reposted all 3 here:
pass:
  â€¢ peixoto, Dell_Brett, asim99
  BS 7533 Pavements constructed with clay, natural stone or concrete pav ir_71 5 4,846 07-04-2019, 03:17 AM
Last Post: concreteok
  BS 5212 Cold applied joint sealant systems for concrete pavements ir_71 3 3,435 03-21-2015, 05:46 PM
Last Post: junaid
  EN 14188-1:2004 Joint fillers and sealants - Part 1: Specifications for hot applied s ir_71 2 2,791 01-18-2015, 09:07 AM
Last Post: Mohammad6299
