Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 15635:2008 Steel static storage systems - Application and maintenance of storage e
01-01-2011, 08:44 PM
EN 15635:2008 Steel static storage systems - Application and maintenance of storage equipment
Author: CEN/TC 344 | Size: 0.55 MB | Format: PDF | Publisher: CEN | Year: 2008 | pages: 61
[Image: 89295735916447117155.jpg]
This European Standard gives guidelines for operational aspects relevant to structural safety of storage
systems. Such systems operate with heavy mechanical handling equipment working in close proximity to
static storage equipment. This European Standard minimizes the risk and consequences of unsafe operation
or damage to the structure. Some other forms of storage equipment are only partially covered and further
consideration, beyond the scope of this European Standard, can be required.
This European Standard gives guidance in conjunction with prEN 15512, EN 15620, and EN 15629 to ensure
that the specifier, user and designer are aware of the constraints in each other’s area to allow a safe design to
be produced.
This European Standard specifically excludes storage equipment manufactured form materials other than
steel (except for certain accessories) and equipment intended to be used for domestic storage purposes
  β€’ Dell_Brett, usman, ziggywas1, roaming79, zrilek
  EN 15629:2008 Steel static storage systems - Specification of storage equipment ir_71 0 2,128 01-01-2011, 08:37 PM
  EN 15620:2008 Steel static storage systems - Adjustable pallet racking - Tolerances, ir_71 0 2,515 01-01-2011, 08:30 PM
  EN 15512:2009 Steel static storage systems β€” Adjustable pallet racking systems - Prin ir_71 0 2,528 01-01-2011, 08:22 PM
  EN 14566:2008 Mechanical fasteners for gypsum plasterboard systems - Definitions, re ir_71 0 1,996 11-17-2010, 05:49 AM
  EN 10340:2008 Steel castings for structural uses ir_71 0 1,994 10-24-2010, 02:44 PM
