Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 1168:2005 Precast concrete products — Hollow core slabs
12-23-2010, 11:50 AM
Author: Technical Committee CEN/TC 229 | Size: 0.8 MB | Format: PDF | Publisher: CEN | Year: 2005 | pages: 60 | ISBN: 0 580 46082 7
[Image: 06125979754527857866.jpg]
This European Standard deals with the requirements and the basic performance criteria and specifies minimum
values where appropriate for precast hollow core slabs made of prestressed or reinforced normal weight concrete
according to EN 1992-1-1:2004.
This European Standard covers terminology, performance criteria, tolerances, relevant physical properties, special
test methods, and special aspects of transport and erection.
Hollow core elements are used in floors, roofs, walls and similar applications. In this European Standard the
material properties and other requirements for floors and roofs are dealt with; for special use in walls and other
applications, see the relevant product standards for possible additional requirements.
The elements have lateral edges provided with a longitudinal profile in order to make a shear key for transfer of
vertical shear through joints between contiguous elements. For diaphragm action the joints have to function as
horizontal shear joints.
The elements are manufactured in factories by extrusion, slipforming or mouldcasting.
The application of the standard is limited for prestressed elements to a maximum depth of 450 mm and a maximum
width of 1 200 mm. For reinforced elements the maximum depth is limited to 300 mm and the maximum width
without transverse reinforcement to 1 200 mm and with transverse reinforcement to 2 400 mm.
The elements may be used in composite action with an in situ structural topping cast on site.
The applications considered are floors and roofs of buildings, including areas for vehicles in the category F and G
of EN 1991-2 which are not subjected to fatigue loading. For building in seismic zones additional provisions are
given in EN 1998-1.
This European Standard does not deal with complementary matters. E.g. the slabs should not be used in roofs
without additional protection against water penetration
  • Dell_Brett, Grunf, usman, almadar12, cordoba123, ilgar, ssi3k, avge, roaming79, zrilek, dbsimon29, peixoto, er.shyams
 st77bel
Romania
User ID: 12964
Threads: 12
Likes: 432 in 86 posts
Given Likes: 696
12-23-2010, 03:00 PM
Hello ashcivilea,
Here you have it:
[-] The following 10 users Like st77bel's post:10 users Like st77bel's post
  • Grunf, toa011, usman, almadar12, cordoba123, ashcivilea, Dell_Brett, zrilek, Trishu999, TAFATNEB
10-05-2012, 04:15 AM
New links:
  • Jackass, malc, vvvv, lisine, ssi3k, Dell_Brett, peixoto, chenamoy, er.shyams
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
01-20-2014, 05:13 PM
Author: Technical Committee CEN/TC 229 | Size: 638 KB | Format: PDF | Quality: Unspecified | Publisher: CEN | Year: 2005 | pages: 60 | ISBN: 0 580 46082 7
[-] The following 4 users Like arshiakh's post:4 users Like arshiakh's post
  • viet2010, milova, st77bel, Dell_Brett
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
04-19-2014, 09:32 AM
[-] The following 7 users Like Dell_Brett's post:7 users Like Dell_Brett's post
  • PinkPant, Mohammad6299, subin91, Agent66, chenamoy, harsono, melekeen
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
03-09-2015, 02:52 PM
[-] The following 9 users Like lisine's post:9 users Like lisine's post
  • zrilek, blaze, PinkPant, bridgeengineer, oanm2000, Dell_Brett, Andrew seah, er.shyams, TAFATNEB
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
03-09-2015, 03:46 PM
Use official password
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 2 users Like Veggeta's post:2 users Like Veggeta's post
  • PinkPant, oanm2000
  BS EN 14629:2007 Products and systems for the protection and repair of concrete structures ir_71 2 3,591 02-11-2022, 09:56 AM
Last Post: CAMSECT
  BS EN 12190:1999 Products and systems for the protection and repair of concrete struc ir_71 2 3,221 11-27-2019, 06:48 AM
  BS 6717:2001 Precast, unreinforced concrete paving blocks — Req and test meth ir_71 2 3,171 07-22-2019, 06:55 AM
Last Post: concreteok
  BS EN 1170-5:Precast concrete products. Test method for glass-fibre reinforced cement yakwetu 2 2,606 04-27-2016, 02:02 PM
Last Post: abualamal
  BS EN 12794:2005-Precast concrete products. Foundation piles PinkPant 0 1,932 06-05-2015, 11:29 AM
Last Post: PinkPant
  BS 4449:2005+A2:2009 Steel for the reinforcement of concrete — Weldable reinfor... portal61 4 4,591 09-16-2014, 12:20 PM
  BS EN 15050 2007: Precast concrete products. Bridge elements peixoto 2 3,705 05-21-2014, 08:25 AM
