Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Case study of the collapse of a water tank: EERL Caltech New Report
 Sumatra
User ID: 14369
Threads: 72
Likes: 1,925 in 240 posts
Given Likes: 1580
12-20-2010, 02:32 AM (This post was last modified: 01-03-2012, 09:17 PM by usman.)
Author: Prof. Swaminathan Krishnan | Size: 13.5 MB | Format: PDF | Publisher: EERL Caltech | Year: 2010
[Image: 13368155342416359671.jpg]
A 48.76m high water tank with the supporting steel lattice comprising 5 segments with uniform member configuration is conceived. Its collapse behavior is investigated through a suite of ground motion analyses. First, the tank is analyzed under 13 three-component ground motion records from the Chi-Chi and Hokkaido earthquakes. It is shown that the tank always collapses in the same manner as a result of overturning due to P-Delta instability resulting from column and brace buckling at the base. This is the consequence of the uniform member sizing in each of the five segments of the supporting lattice. Incremental dynamic analyses are performed using the Takatori near-source record from the 1995 Kobe earthquake. It is shown that the structure collapses at a ground motion scaling factor of 0.32.
DIRECT LINKS thumbup
[-] The following 12 users Like Sumatra's post:12 users Like Sumatra's post
  â€¢ usman, kowheng, Dell_Brett, oanm2000, sasan7351, yantonegr, cristi, spat, fer962933, zrilek, Quantumm, triance
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
04-16-2012, 12:23 PM
Direct link / 32.7MB
[-] The following 12 users Like lisine's post:12 users Like lisine's post
  â€¢ kowheng, seriousboy, zrilek, ingchio, slowet, pedzaquino, triance, terrorruban, draluka, Jackass, Dell_Brett, Sumatra
  MODELING OF WATER TANK UNDER SEISMIC EXCITATION aslam 1 2,935 03-18-2011, 06:20 AM
