Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 1916 Concrete pipes and fittings, unreinforced, steel fibre and reinforced
 datagap
User ID: 24267
Threads: 46
Likes: 695 in 68 posts
Given Likes: 176
12-14-2010, 08:23 AM
EN 1916:2002 Concrete pipes and fittings, unreinforced, steel fibre and reinforced
Author: Technical Committee CEN/TC 165 Wastewater engineering | Size: 0.63 MB | Format: PDF | Publisher: CEN | Year: 2002 | pages: 90 |
[Image: 94840929333182761736.jpg]
This European Standard specifies performance requirements as defined in Table 1 and describes test methods for precast concrete pipes and fittings, unreinforced, steel fibre and reinforced, with flexible joints (with seals either integrated in the units or supplied separately) and nominal sizes not exceeding DN 1 750 for units with a circular bore or WN/HN 1 200/1 800 for units with an egg-shaped bore, for which the main intended use is the conveyance of sewage, rainwater and surface water under gravity or occasionally at low head of pressure, in pipelines that are
generally buried.
Provision is made for the evaluation of conformity of units to this European Standard.
Marking conditions are included.
Made By [b]CivilEA Post-Generator ver 2.0
[-] The following 9 users Like datagap's post:9 users Like datagap's post
  â€¢ kowheng, rkce, Grunf, chigozie, rezart, toa011, marcala, salahcivil, Dell_Brett
 rkce
User ID: 25910
Threads: 56
Likes: 717 in 122 posts
Given Likes: 1282
12-14-2010, 08:42 AM
Mirror
[-] The following 4 users Like rkce's post:4 users Like rkce's post
  â€¢ Grunf, blaze, chigozie, rezart
12-14-2010, 02:39 PM (This post was last modified: 12-24-2014, 12:24 PM by oanm2000.)
EN 1916:2002/AC - Annex to EN 1916
Author: CEN/TC 165 | Size: 0.3 MB | Format: PDF | Publisher: CEN | Year: 2006 | pages: 19
Add in the first sentence "for use in pipelines" after " ... and reinforced, ":
"This European Standard specifies performance requirements as defined in Table 1 and describes test methods for precast concrete pipes and fittings, unreinforced, steel fibre and reinforced, for use in pipelines with flexible joints (with seals either integrated in the units or supplied separately) and nominal sizes not exceeding DN 1 750 for units with a circular bore or WN/HN 1 200/1 800 for units with an egg-shaped bore, for which the main intended use is the conveyance of sewage, rainwater and surface water under gravity or occasionally at low head of pressure, in pipelines that are generally buried."
  â€¢ kowheng, toa011, datagap, Grunf, usman, k1k0k0, dbsimon29, lisine, Dell_Brett
 f_slikken
User ID: 21091
Threads: 9
Likes: 910 in 88 posts
Given Likes: 778
12-24-2014, 08:48 AM
Hi,
Here you go:
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 9 users Like f_slikken's post:9 users Like f_slikken's post
  â€¢ PinkPant, blaze, lisine, oanm2000, knrsa, dinu69in, bridgeengineer, malc, Dell_Brett
Likes: 8,311 in 1,373 posts
Given Likes: 92
02-13-2022, 11:44 AM
  â€¢ zrilek, CAMSECT, babakfeyzi, Dell_Brett, Administrator , oanm2000
  EN 1092 Flanges and their joints — Circular flanges for pipes, valves, fittings and a ir_71 1 2,570 05-14-2015, 01:50 PM
Last Post: PinkPant
  EN 545:2010 Ductile iron pipes, fittings, accessories and their joints for water pipe ir_71 2 3,414 07-17-2014, 08:36 AM
  EN 1917:2002 + AC:2006 Concrete manholes and inspection chambers, unreinforced, steel ir_71 0 2,211 12-14-2010, 05:47 PM
