Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 4551:2005 Mortar — Methods of test for mortar - Chemical analysis and physical tes
12-07-2010, 02:40 PM (This post was last modified: 12-07-2010, 04:06 PM by oanm2000.)
BS 4551:2005 Mortar — Methods of test for mortar - Chemical analysis and physical testing
Author: BSI Subcommittee B/519/2. | Size: 0.6 MB | Format: PDF | Publisher: BSI | Year: 2005 | pages: 42 | ISBN: 0 580 46454 7
[Image: 27529141117578805673.jpg]
This British Standard specifies methods of sampling preparation, physical testing and chemical analysis of mortars for bricklaying, plastering and rendering. The methods described are for the determination of parameters that have traditionally been used in the UK but which are neither defined, nor superseded, by BS EN 998-1, BS EN 998-2 or BS EN 1015 (all parts).
Methods of interpretation of chemical analysis results are also described.
The methods of test given in this standard are not intended to be applied to mortars containing high alumina cement or mortars whose principle binder is hydraulic lime.
  • kowheng, oanm2000, usman, Grunf, Adam Smith, toa011, Dell_Brett, zrilek, roaming79, parwez007, st77bel, uetian19
09-29-2012, 04:37 AM
New working links:
  • lisine, Dell_Brett, st77bel, peixoto, miquan, Trishu999
  ISO 22762-1: Elastomeric seismic-protection isolators Part 1: Test methods poolmand 0 2,956 11-16-2024, 01:18 PM
  BS 7910:2005 Guide to methods for assessing the acceptability of flaws in metallic st ir_71 4 4,069 03-04-2020, 08:08 PM
Last Post: sabooryan
  BS EN 1340/AC:2006 Concrete kerb units - Requirements and test methods ir_71 2 3,150 07-22-2017, 07:41 AM
  BS EN 1097-2:2010 Tests for mechanical and physical properties of aggregates. Methods ir_71 1 2,367 07-21-2017, 04:39 PM
  BS EN 1338:2003 Concrete paving blocks. Requirements and test methods mybest 5 4,758 02-28-2016, 12:56 PM
  BS EN 196-5:2011 Methods of testing cement Part 5: Pozzolanicity test for pozzolanic ir_71 1 2,286 04-14-2015, 05:03 PM
Last Post: Veggeta
  BS EN 12859:2011 Gypsum blocks - Definitions, requirements and test methods ir_71 3 3,288 12-27-2014, 10:34 PM
Last Post: Veggeta
