Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 440.1: Guide for the Design and Construction of Structural Concrete...
Threads: 1,298
12-03-2010, 10:16 AM (This post was last modified: 05-03-2023, 08:48 AM by Administrator.)
ACI 440.1R-06 Guide for the Design and Construction of Structural Concrete Reinforced with FRP Bars
Author: ACI Committee 440 | Size: 1.28 MB | Format: PDF | Publisher: ACI | Year: 2006 | pages: 44
[Image: 11529282042292420906.jpg]
This document provides recommendations for the design and construction of FRP-reinforced concrete structures. The document only addresses nonprestressed FRP reinforcement (concrete structures prestressed with FRP tendons are covered in ACI 440.4R). The basis for this document is the knowledge gained from worldwide experimental research, analytical research work, and field applications of FRP reinforcement. The recommendations in this document are intended to be conservative.
Design recommendations are based on the current knowledge and intended to supplement existing codes and guidelines for conventionally reinforced concrete structures and to provide engineers and building officials with assistance in the specification, design, and construction of structural concrete reinforced with FRP bars.
ACI 440.3R provides a comprehensive list of test methods and material specifications to support design and construction guidelines.
The use of FRP reinforcement in combination with steel reinforcement for structural concrete is not addressed in this document.
  • kowheng, ISTRAKTURA, vardan, jcoronellr, kmmh76, usman, Quantumm, super_engineer, sodapas, jcbv, oanm2000, sivlad, nuttapolk, vvvv, bigone, ykhackhack
 junaid
User ID: 402
Threads: 209
Likes: 8,170 in 732 posts
Given Likes: 983
01-27-2014, 05:13 AM
[-] The following 13 users Like junaid's post:13 users Like junaid's post
  • subin91, malc, ssobhan, vvvv, bigone, oanm2000, simanta, Rapaig, ykhackhack, st77bel, uncblue, sacem, Munykong
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
ACI PRC-440.1-15 Guide for the Design and Construction of Structural Concrete Reinforced with Fiber-Reinforced Polymer Bars
Author(s)/Editor(s): ACI Committee 440 | Size: 4.78 MB| Format: PDF| Quality: Original preprint| Year: 2021| pages: 88
[Image: 88300688720689359947.png]
Fiber-reinforced polymer (FRP) materials have emerged as an alternative for producing reinforcing bars for concrete structures. Fiber-reinforced polymer reinforcing bars offer advantages over steel reinforcement because they are noncorrosive. Some FRP bars are nonconductive as well. Due to other differences in the physical and mechanical behavior of FRP materials versus steel, unique guidance on the engineering and construction of concrete structures reinforced with FRP bars is necessary. Other countries and regions, such as Japan, Canada, and Europe have established design and construction guidelines specifically for the use of FRP bars as concrete reinforcement. This guide offers general information on the history and use of FRP reinforcement, a description of the unique material properties of FRP, and guidelines for the design and construction of structural concrete members reinforced with FRP bars. This guide is based on the knowledge gained from worldwide experimental research, analytical work, and field applications of FRP reinforcement.
Keywords: anchorage (structural); aramid fiber; carbon fiber; crack control; concrete construction; concrete slabs; cover; creep rupture; deflections; design examples; durability; fiber-reinforced polymer; flexural strength; glass fiber; moments; reinforced concrete; reinforcement; serviceability; shear strength; spans; strength analysis; stresses; structural concrete; structural design.
  • Dell_Brett, babakfeyzi, PinkPant, milova, subin91, Umer.Aleem
  [CivilEA Exclusive] ACI PRC-357.3: Design and Construction of Waterfront and Coastal Concrete Marine Stru poolmand 0 797 12-06-2025, 11:09 AM
  [CivilEA Exclusive] ACI 357: Design and Construction of Fixed Offshore Concrete Structures poolmand 0 1,799 12-14-2024, 01:11 PM
  ACI SP-343: Fibre Reinforced Concrete: From Design to Structural Applications poolmand 0 1,802 03-04-2024, 07:50 AM
  ACI 549.4: Guide to Design and Construction of Externally Bonded Fabric-Reinforced Ce poolmand 0 1,629 01-23-2024, 12:10 PM
  ACI 440.2: Guide for the Design and Construction of Externally Bonded FRP Systems ir_71 5 5,633 01-17-2024, 07:34 AM
  ACI 526: Guide for Design and Construction with Autoclaved Aerated Concrete Panels poolmand 0 1,883 01-17-2024, 07:27 AM
  ACI 343.1 Guide for the Analysis and Design of Reinforced and Prestressed Concrete Gu poolmand 0 1,939 11-26-2023, 11:51 AM
