Civil Engineering Association eBooks Codes, Manual & Handbook ISO ISO 1099:2006 Metallic materials — Fatigue testing - Axial force-controlled method
11-15-2010, 11:20 AM (This post was last modified: 11-15-2010, 12:14 PM by Grunf.)
ISO (the International Organization for Standardization) is a worldwide federation of national standards bodies (ISO member bodies). The work of preparing International Standards is normally carried out through ISO technical committees. Each member body interested in a subject for which a technical committee has been established has the right to be represented on that committee. International organizations, governmental and
non-governmental, in liaison with ISO, also take part in the work. ISO collaborates closely with the International Electrotechnical Commission (IEC) on all matters of electrotechnical standardization. International Standards are drafted in accordance with the rules given in the ISO/IEC Directives, Part 2. The main task of technical committees is to prepare International Standards. Draft International Standards adopted by the technical committees are circulated to the member bodies for voting. Publication as an International Standard requires approval by at least 75 % of the member bodies casting a vote. Attention is drawn to the possibility that some of the elements of this document may be the subject of patent rights. ISO shall not be held responsible for identifying any or all such patent rights.
ISO 1099 was prepared by Technical Committee ISO/TC 164, Mechanical testing of metals, Subcommittee SC 5, Fatigue testing. This second edition cancels and replaces the first edition (ISO 1099:1975), which has been technically revised.
:JC_cheers:
  • kowheng, Dell_Brett, toa011, Grunf, oanm2000, peixoto, roaming79
Threads: 49
01-14-2013, 02:44 PM
link dead; mirror
password
[-] The following 2 users Like andersen3's post:2 users Like andersen3's post
  • slowet, Dell_Brett
Threads: 49
01-08-2015, 03:41 PM
new links
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
password:
  • jcbv, Dell_Brett, PinkPant, bridgeengineer, scorpion07
  ISO 3834: Quality requirements for fusion welding of metallic materials mybest 7 5,156 01-08-2015, 05:35 PM
  ISO 12737:2005 Metallic materials -- Determination of plane-strain fracture toughne ir_71 2 2,915 01-08-2015, 04:13 PM
  ISO 12106:2003 Metallic materials — Fatigue testing ir_71 2 3,147 01-08-2015, 04:11 PM
  ISO 17635:2010 Non-destructive testing of welds — General rules for metallic material ir_71 2 3,878 01-08-2015, 04:01 PM
