Civil Engineering Association eBooks Codes, Manual & Handbook EN EN ISO 17660 Welding. Welding of reinforcing steel.
11-11-2010, 05:22 AM
BS EN ISO 17660-1:2006 Welding. Welding of reinforcing steel. Load-bearing welded joints
Reinforcing steel bars are produced by a number of process routes and usually have a ribbed profile. Taking these issues into account, it is apparent that both the welder and the welding coordinator require a specific level of skill and job knowledge and that special procedures for quality assurance need to be adopted.
BS EN ISO 17660-1 is applicable to the welding of weldable reinforcing steel and stainless reinforcing steel of load-bearing joints, in workshops or on site. It specifies requirements for materials, design and execution of welded joints, welding personnel, quality requirements, examination and testing.
BS EN ISO 17660-1also covers welded joints between reinforcing steel bars and other steel components, such as connection devices and insert anchors, including prefabricated assemblies. Non load-bearing joints are covered by BS EN ISO 17660-2.
BS EN ISO 17660-1 is not applicable to factory production of welding fabric and lattice girders using multiple spot welding machines or multiple projection welding machines.
The requirements of BS EN ISO 17660-1 are only applicable to static loaded structures.
BS EN ISO 17660-2:2006 Welding. Welding of reinforcing steel. Non load-bearing welded joints
BS EN ISO 17660-2 is applicable to the welding of weldable reinforcing steel and stainless reinforcing steel of load-bearing joints, in workshops or on site. It specifies requirements for materials, design and execution of welded joints, welding personnel, quality requirements, examination and testing.
BS EN ISO 17660-2 also covers welded joints between reinforcing steel bars and other steel components, such as connection devices and insert anchors, including prefabricated assemblies. Non load-bearing joints are covered by BS EN ISO 17660-2.
BS EN ISO 17660-2 is not applicable to factory production of welding fabric and lattice girders using multiple spot welding machines or multiple projection welding machines.
The requirements of BS EN ISO 17660-2 are only applicable to static loaded structures.
:JC_cheers:
  â€¢ kowheng, Grunf, Dell_Brett, zrilek, buraz, vvvv, jcbv, peixoto, toa011, chenamoy, oanm2000, pssst
Threads: 49
10-22-2014, 12:51 PM
new links
password
[-] The following 8 users Like andersen3's post:8 users Like andersen3's post
  â€¢ oanm2000, PinkPant, amindoxiti, zrilek, malc, rigid_joint, jcbv, Dell_Brett
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
12-05-2018, 11:50 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 14 users Like febo927's post:14 users Like febo927's post
  â€¢ amindoxiti, agelos100, Aviator, rendel_©, blaze, chenamoy, carolinandra, oanm2000, jcbv, gulilero, zrilek, Dell_Brett, PinkPant, subin91
  EN 1011-1:2009 Welding — Recommendations for welding of metallic materials Part 1: Ge ir_71 2 3,695 04-09-2017, 04:00 AM
