Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI SP 183: The Design of Two-way Slabs
 miquan
Vietnam
User ID: 631
Threads: 171
Likes: 3,748 in 387 posts
Given Likes: 1331
11-10-2010, 08:45 AM (This post was last modified: 02-06-2024, 08:39 AM by Administrator.)
SP-183 The Design of Two-way Slabs
[Image: 25610591485528888069.jpg]
Title: SP-183: Design of Two-Way Slabs
Year of Publication: 1999
Number of Pages: 183
Order Code: SP183
Abstract: Editor: T. C. Schaeffer
This Symposium Publication consists of 10 papers that give the designer an overview of some of the different analysis and design techniques currently being used.
Note: The individual papers are also available as .pdf downloads. Please click on the following link to view the papers available, or call 248.848.3800 to order.
VIEW THE PAPERS
Contents: * Concept & Background of Elastic Frame Analogies for Two-Way Slab Systems by S. Simmonds
* Design for Severe Dynamic Loads by S. Woodson & T. Krauthmmer
* Design for Punching Shear in Concrete by S. Megally and A. Ghali
* Developments in Yield Line Theory for Slabs by W. Gamble
* Using Theorums of Plasticity: History & Concept by S. Simmonds
* Strip Method for Flexural Design of Two-Way Slabs by S. Alexander
* Plane-Frame Anaylsis Applied to Slabs by W. Gamgle
* Detailing for Serviceability by D. Rogowsky
* Design & Construction of Two-Way Slabs for Defelection Control by A. Scanlon
* Strip Design for Punching Shear by S. Alexander
[-] The following 80 users Like miquan's post:80 users Like miquan's post
  β€’ ISTRAKTURA, kowheng, Dell_Brett, peixoto, parhyang, robertsas, HellboyRBJ, rezart, engr1900, vvvv, engrezi, hatkam, cace-01, planeti_x, vardan, toa011, hmwere, Grunf, sujups, ravisbassi, shanta, melkat, snw1975, ssi3k, parwez007, poite, Petrit, Quantumm, osin, zrilek, super_engineer, ziggywas1, Adam Smith, jasaldana, oanm2000, Hengki, sodapas, diotviet, pedzaquino, gulilero, ruaumoko, agelos100, Nilupa, yucapareja, jokerβ„’, malc, techno, theanhpe, triance, yutt, knrsa, dbsimon29, slowet, nuttapolk, melekeen, Rami11, Jackass, jayborre, nigema, i_kabir, subin91, salahcivil, bigone, arceon, tattiya, chairatpk, erimajus, anorona, SCREAM7890, blaze, odiclas, simanta, Mohammad6299, ranger, pram, inge911, neikrof, cabpcabp, moh_towhid, spat
 ynopum
Burundi
User ID: 2733
Threads: 24
Likes: 2,399 in 365 posts
Given Likes: 155
01-29-2012, 07:40 PM
The same book, the same scan, but with split pages, black&white, OCR layered, DjVu, size less than 3 MB (suitable for pocket devices):
I would recommend you to keep both versions, because the previous grayscale scan has more detail in the very small indexes, especially those on the graphic schemes.
[-] The following 9 users Like ynopum's post:9 users Like ynopum's post
  β€’ Grunf, Dell_Brett, gulilero, slowet, kerenski_t, melekeen, marion33, SCREAM7890, techno
Likes: 8,311 in 1,373 posts
Given Likes: 94
05-07-2023, 12:04 PM
| Size: 6.67 MB| Format: PDF| Quality: Scanner| Year: 1999| pages: 183 | ISBN: 9780870316821
Table of Contents
- Concept & Background of Elastic Frame Analogies for Two-Way Slab Systems by S. Simmonds
- Design for Severe Dynamic Loads by S. Woodson & T. Krauthmmer
- Design for Punching Shear in Concrete by S. Megally and A. Ghali
- Developments in Yield Line Theory for Slabs by W. Gamble
- Using Theorums of Plasticity: History & Concept by S. Simmonds
- Strip Method for Flexural Design of Two-Way Slabs by S. Alexander
- Plane-Frame Anaylsis Applied to Slabs by W. Gamgle
- Detailing for Serviceability by D. Rogowsky
- Design & Construction of Two-Way Slabs for Defelection Control by A. Scanlon
- Strip Design for Punching Shear by S. Alexander
  β€’ babakfeyzi, PinkPant, milova, Dell_Brett
  ACI SP-353: Design of Slabs for Serviceability and Punching Shear Strength poolmand 0 1,816 03-04-2024, 07:24 AM
  ACI 360: Design of Slabs on Grade mastermind 17 9,626 05-09-2023, 08:26 AM
  ACI 447R-18 Design Guide for Twisting Moments in Slabs sabooryan 2 2,828 05-09-2023, 08:19 AM
