Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 14843:2007 Precast concrete products - Stairs
10-29-2010, 04:02 AM
This standard gives specifications for materials, production, properties, requirements and methods of testing for precast concrete monolithic stairs, and for precast concrete elements (e.g. individual steps) used to make reinforced and/or prestressed concrete stairs.
This standard is applicable to structural stairs for indoor or outdoor use.
This standard covers precast concrete stairs and associated landings of monolithic design or constructed from individual steps supported by beams or columns. Supporting elements may include in situ concrete.
This standard covers terminology, performance criteria, verification methods, tolerances, relevant physical properties, special test methods and specific aspects of transport, erection and connection.
Geometrical properties related to functionality of stairs are not covered by this standard and can be found in National regulations or local practice.
Precast concrete stairs are classified into two main product families :
п‚ѕ monolithic stairs constructed from precast concrete components consisting of flights, landings or a combination of these. They may include vertical supporting elements ;
п‚ѕ stairs constructed from individual steps, whether load bearing or not, assembled on site with, for example, carriages or a central column.
Their shape may be straight or winding.
Stairs may incorporate parapets (on one or both sides) and landings.
Stairs may have simple bearings (e.g. on corbels, walls or beams), bolted connections or they may be connected with reinforcement and in situ concrete.
The surfaces of the precast elements may be exposed or covered by finishes.
:JC_cheers:
  • kowheng, Grunf, ssi3k, peixoto, we_mbm, Dell_Brett, jcoronellr, ruaumoko, st77bel, cordoba123, chenamoy, roaming79, toa011, kmmh76, vvvv
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42508
10-29-2010, 09:20 AM
Dear ir_71,
Some time ago, Grunf was done an excellent job joining all EUROCODES.
Consider do the same with yours (excellent too!) posts about British Standards.
Thanks a lot.
Dell Brett
[-] The following 5 users Like Dell_Brett's post:5 users Like Dell_Brett's post
  • Grunf, peixoto, oanm2000, cordoba123, hmwere
10-29-2010, 04:55 PM
Dear Dell Brett,
I think the idea is very good. We can classify Euronorms in different sections - concrete, precast elements, metalic materials and other.
I will have a little trip around the country next ten days. I can do more for realization of the idea when I am back.
IR
  • Dell_Brett, cordoba123, Grunf, hmwere
  EN 13791:2007 Assessment of in-situ compressive strength in structures and precast co ir_71 4 5,972 02-15-2022, 06:23 AM
Last Post: CAMSECT
  EN 13369:2004 (Common rules for precast concrete products) raffah 2 3,643 03-07-2018, 01:53 PM
  EN 12843:2004 Precast concrete products - Masts and poles ir_71 3 3,953 01-24-2015, 01:19 AM
Last Post: concreteok
  EN 14992:2007 Precast concrete products - Wall elements ir_71 1 2,935 01-20-2014, 03:27 PM
Last Post: milova
  EN 12794:2005 Precast concrete products - Foundation piles ir_71 1 2,864 04-11-2013, 01:59 AM
Last Post: st77bel
  EN 15037 Precast Concrete Products. Beam-and-block floor systems ir_71 0 2,325 12-14-2010, 04:02 AM
  EN 15015:2007 Precast concrete products - Bridge elements ir_71 0 2,226 10-24-2010, 05:21 AM
