Civil Engineering Association Software Software Product Autodesk Products RISA/Revit Structure 2011 Link 9.0
 goober
United States
User ID: 3294
Threads: 3
Likes: 227 in 47 posts
Given Likes: 402
10-27-2010, 03:28 PM
Revit Structure users can now leverage the full power of Building Information Modeling by synchronizing their Revit Structure models with RISA-3D and/or RISAFloor. As an Autodesk Authorized Developer, RISA Technologies has created a full-fledged bi-directional exchange link with Revit Structure.
New models can be created in either Revit Structure or RISA software using the information available in the other program. All geometric and design information including materials, family instances, walls, slabs, openings, grid lines, boundary conditions, footings, loads and load combinations can be created/updated/deleted in either of the two programs using the information available in the other program.
The new exchange file method allows continuity of data flow throughout the exchange cycle. Users can add new elements and/or additional design to the RISA model and these changes will be retained in RISA while round-tripping.
The robust Excel based XML mapping file provides the capability to customize the processing of shapes, materials and load cases. A log file is created during every export/import operation giving a synopsis on the number of elements translated and errors/warnings encountered, if any.
Link Version......RISA-Revit Link 9.0
Compatibility – Revit Structure........Revit Structure 2011 (32-bit or 64-bit)
Compatibility – RISA......RISA-3D 8.1.3 or higher & RISAFloor 4.1.4 or higher
[Image: 02445319488765034388.jpg]
[-] The following 12 users Like goober's post:12 users Like goober's post
  β€’ kln258, sasan7351, oanm2000, Dell_Brett, zrilek, rezart, Vufor, engr1900, haze, dbsimon29, spat, inglugo
  AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 11,764 04-21-2018, 09:51 PM
Last Post: jokerβ„’
  Autodesk Revit Structure 2016 (x64) BennyP 3 11,825 08-26-2015, 04:22 PM
Last Post: er.shyams
  Autodesk Revit Structure 2015.2 (x64) BennyP 0 5,204 12-23-2014, 05:27 PM
  Autodesk Revit Structure 2015 x64 BennyP 6 11,468 08-06-2014, 01:17 PM
Last Post: i_kabir
  Autodesk Revit Structure 2013 (x32 + x64) BennyP 6 14,536 11-18-2012, 07:13 AM
Last Post: araza023
  Autodesk Revit Structure 2012 (32 and 64 bit) BennyP 4 14,669 02-03-2012, 03:46 PM
  Autodesk Revit Structure Suite 2009 cod-X 3 9,912 02-26-2011, 05:05 PM
Last Post: RICARDI
