Civil Engineering Association eBooks Structural Books Steel Earthquake Resistant Steel Structures
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
06-25-2009, 10:55 AM
Earthquake Resistant Steel Structures - Arcelor Mittal article
I just received a Newsletter "Constructalia nΒΊ6" June 2009, and I'd like to share a free article: Earthquake Resistant Steel Structures.
It's a PDF file, 5,5 Mb
This document aims to present in a straightforward manner the essentials of seismic design of steel structures, which is a field of engineering and construction to which ArcelorMittal contributes by continuous research efforts that bring better steel products and original design solutions to the market.
Contents:
1. What is an Earthquake?
2. Why are Steel Structures Good at Resisting Earthquakes?
3. A Tool to Evaluate the Effects of Earthquakes: the Response Spectrum
4. Design Response Spectra
5. Characterisation of Structures Specific to Seismic Design
6. Aspects of Seismic Analysis and Design Checks Common to all Structural Types
7. Approximate Method for Seismic Analysis and Design
8. Architecture of Earthquake Resistant Buildings
9. Designing Dissipative Structures
10. Seismic Design of Moment Resisting Frames
11. Seismic Design of Frames with Concentric Bracing
12. Seismic Design of Frames with Concentric Bracing and Dissipative Connections
13. Seismic Design of Frames with Eccentric Bracing
14. Composite Steel Concrete Structures
15. Composite Steel Concrete Moment Resisting Frames
16. Composite Steel Concrete Frames with Bracing
17. Composite Steel Concrete Walls and Systems with Walls
18. Improving Reinforced Concrete Structures by using Composite Columns
19. Design Example.
screenshots:
[Image: 154uc9h.jpg]
[Image: akk2f8.jpg]
[-] The following 35 users Like Dell_Brett's post:35 users Like Dell_Brett's post
  β€’ abudabeeja, abudabeeja, verongskey, verongskey, aslam, aslam, oanm2000, oanm2000, Ultra Zone, Ultra Zone, amirdana, amirdana, simanta, simanta, cristi, cristi, zrilek, zrilek, Thanhtung, Thanhtung, junaid, junaid, civilphongvan, amira, zainseiya, ISTRAKTURA, tecnatech, Grunf, Nilupa, oram, andersen3, Sumatra, spy1551, ykhackhack, bigone
Threads: 49
11-09-2012, 11:45 AM
link dead; reposted here
or direct link
[-] The following 16 users Like andersen3's post:16 users Like andersen3's post
  β€’ Sumatra, vardan, seriousboy, blaze, gulilero, ykhackhack, bigone, Jackass, cace-01, sodapas, ruaumoko, Dell_Brett, eliseo.as, simanta, inge911, febo927
  design and analysis of fatigue resistant welded structures david-smith 2 2,782 07-20-2018, 04:15 AM
Last Post: axcel
  Ductility of Seismic Resistant Steel Structures ribak 6 8,215 07-20-2018, 04:06 AM
Last Post: axcel
  SEISMIC RESISTANT STEEL STRUCTURES amindoxiti 0 2,104 10-28-2014, 03:49 AM
  Moment Resistant Connections of Steel Frames in Seismic Areas: Design and Reliability Grunf 4 5,619 09-07-2014, 09:44 PM
Last Post: apocalipse
  SCI P080: Fire resistant design of steel structures - A handbook to BS 5950: Part 8 ir_71 2 3,025 05-14-2014, 05:33 AM
  Seismic Design of Seismic-Resistant Steel Building Structures TAFATNEB 0 1,887 08-31-2013, 09:44 AM
