Civil Engineering Association Software Software Product Autodesk Products AUTODESK FACTORY DESIGN SUITE PREMIUM 2011 WIN32 & WIN64
Threads: 1,118
10-07-2010, 06:31 AM
WIN32: 6.84 GB | WIN64: 7.40 GB
Create Compelling 3D Visual Layouts. Autodesk® Factory Design Suite Premium 2011 software is designed for the layout user who needs to create compelling 3D visual layouts of machine lines and entire manufacturing facilities. * Create or import 2D layouts, * Drop intelligent 3D factory content on top of the 2D floor plan, * Easily try different “what-if” scenarios, * Communicate ideas and build layout proposals in 3D.
Includes:
AutoCAD® Architecture
Autodesk® Inventor®
Autodesk® Navisworks® Simulate
Autodesk® Vault®
Autodesk® Factory Design Utilities
Downloaded from the hotfile link and installed 64bit version. A lot of time for downloading, a lot of time for burning and the same for installation. Need a double layer DVD, when installing build a temporary folder of 13.7 GB and the installation folder is 7.44GB. Not checked other folders Autodesk install more. The screenshots are from the installation process, see the dots in the lower side of first one (continue to the second) and other dots in the lower side of the second, continue (enough screenshots). A real dinosaur.
[Image: 46830944216078093710.gif]
[Image: 67828434771514955957.gif]
  • cordoba123, BennyK, ilgar, snakes, oanm2000
  Autodesk Infrastructure Design Suite Ultimate 2021 giovas 0 4,634 04-20-2020, 08:32 PM
Last Post: giovas
  Autodesk Infrastructure Design Suite Ultimate 2020 giovas 0 5,157 08-04-2019, 04:50 PM
Last Post: giovas
  AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 11,764 04-21-2018, 09:51 PM
Last Post: joker™
  AutoDesk Infrastructure Design Suite Ultimate 2018 giovas 0 5,691 06-11-2017, 04:08 PM
Last Post: giovas
  Autodesk Product Design Suite Ultimate 2018 BennyP 0 5,382 04-15-2017, 01:11 PM
  Autodesk Building Design Suite Ultimate 2018 BennyP 0 5,151 04-14-2017, 02:00 PM
  AutoDesk Infrastructure Design Suite Premium 2018 BennyP 0 4,974 04-14-2017, 01:34 PM
