Civil Engineering Association Software Software Product Non Engineering Software ESET NOD32 On-Demand Scanner Portable
 paladin
User ID: 27662
Threads: 35
Likes: 243 in 64 posts
Given Likes: 86
10-07-2010, 05:58 AM
[Image: 54006594122325001816.jpg]
Antivirus protection is spelled NOD32. Built on the award-winning ThreatSense engine, ESET NOD32 Antivirus software proactively detects and eliminates more viruses, trojans, worms, adware, spyware, phishing, rootkits and other Internet threats than any program available.
No matter what your system, there is no better antivirus protection. ESET NOD32 Antivirus was awarded the "BEST Antivirus Solution” in 2006 and 2007 by AV-Comparatives. Compare antivirus solutions here to learn more, or check out the latest Virus Bulletin.
ESET NOD32 Antivirus provides:
Proactive Protection: The award winning ThreatSense technology combines multiple layers of detection protecting you from Internet threats before it is too late.
Precise Detection: ESET accurately identifies known and unknown threats. It consistently wins top awards from testing labs and is recognized for having zero false positives.1
iLghtweight Design:
Requires less memory and CPU power, allowing your computer to run fast, making more room for games, web browsing, and emailing.
Fast Scanning Speeds: Highly efficient program ensuring fast file scanning and product updates. It runs quietly in the background.
[-] The following 3 users Like paladin's post:3 users Like paladin's post
  β€’ barukai, BennyK, ravisbassi
 A.Brent
User ID: 29866
Likes: 7 in 2 posts
Given Likes: 0
10-12-2010, 04:34 AM (This post was last modified: 10-12-2010, 04:46 AM by kowheng.)
i need a keygen to this , plz share if you know how to generate the keys . thanks
Please remove URL from your signature. It's considered as transparent link which is not allowed in this forum. After this note, every post you did, you'll be warned for transparent link (+1 point for first time, +4 points for second time and so on).
  β€’
 paladin
User ID: 27662
Threads: 35
Given Likes: 86
10-13-2010, 08:34 AM
Hi A.Brent
No need keygen for "ESET NOD32 On-Demand Scanner Portable"
Portable = no need installation & no need crack/keygen/medicine
It's work, I try it by my self
Okay, I will guide you how to use it
[1] run the file : nod32_20101004_5503.exe
[2] Click "Next > " button
[3] Do not check "Scan all files", keep it uncheck, click "Next > " button
[4] If you want to scan USB flash-disk :
a) insert it ( the usb flash-disk ) first then repeat step no 1 untilstep no 3 above & follow step b until step e below
b) if want scan usb flash-disk only, uncheck red-check at drive C & D ( use double click at drive c & D )
c) now the red check only at the usb flash-disk only
d) click "scan only" or "scan & clean" choose which command you want
e) to scan other click tab named "Scanning target"
[5] If want to scan a file, first follow step 1 until 3 above then follow steps below :
a) click "Add" button
b) click "Folder" button, find the folder where the file you want to scan is located ( you can only select the folder / location where a file you want to scan is located )
c) if want scan file only, uncheck red-check at drive C & D
[6] If want check all your computer ( for example consist of 2 drive : C & D )
a) first follow step 1 until 3 above then follow steps below
b) don't uncheck red-check of drive c & D
c) click "scan only" or "scan & clean" choose which command you want
d) to scan other click tab named "Scanning target"
I think my explanation above is very clear, I hope you can understand it.
Thanks
Paladin
[-] The following 1 user Likes paladin's post:1 user Likes paladin's post
  β€’ BennyK
 Batman07
User ID: 22745
Threads: 35
Likes: 629 in 84 posts
Given Likes: 735
01-23-2011, 05:49 AM
Program for ESET NOD32 License
1. No need for cracks
2. No need for keygens
3. No need to search license on google
Just install this program, and let the program do it for you.
[Image: 3e856d.jpg]
New version of the utility that inserts a valid license to update NOD32 Commercial versions 2.5.x, 2.7.x, 3.x, 4.0.x, 4.2.x, including Eset Smart Security.
- Improved compatibility with Vista and 7.
- Review of Licensing in parallel, by default 5 licenses are reviewed at a time (configurable).
- Configuration Window renewed, now allows you to configure inter alia: personal server management licenses, manual proxy settings, language manual, avoiding trial licenses and licenses that expire soon.
- Compatibility with NOD32 4.2.
- Added a downloader licenses.
- Added an option to insert the license with the highest expiration date.
[-] The following 2 users Like Batman07's post:2 users Like Batman07's post
  β€’ jaks, 3fan
  ESET NOD32 Antivirus & Smart Security 4.0.467 [x32 & x64] kardels 7 13,326 12-21-2009, 12:24 PM
Last Post: pezhmankhan
