Civil Engineering Association Software Software Product Non Engineering Software AnyBizSoft PDF Converter 2.0.0.1
 paladin
User ID: 27662
Threads: 35
Likes: 243 in 64 posts
Given Likes: 86
09-19-2010, 07:34 AM
[Image: 84246562297549495213.jpg]
AnyBizSoft PDF Converter 2.0.0.1 | 9.13 MB
AnyBizSoft PDF Converter - is easy to use program that is specifically designed for converting PDF files into Microsoft Word, Microsoft Excel, Microsoft PowerPoint, HTML and text documents. Just with a few clicks, you can convert PDF-files in the target format with amazing skorostyu.Ishodny appearance of text, images, and hyperlinks can be exactly stored in the generated Word, PowerPoint and HTML dokumentah.S AnyBizSoft PDF Converter, you can import about 200 PDF-files for a batch conversion, or select a specific range of pages.
Features:
• Convert PDF files into editable Microsoft Word 2002-2010 format (. DOC,. DOCX)
- Retain the original text contents, images, and format
• Convert PDF files into editable Microsoft Excel 2003/2007/2010 (. Xls,. Xlsx)
• Convert PDF files into Microsoft PowerPoint 2002-2010 format (. PPT,. PPTX)
- Retain the original format, layout images
• Convert PDF files into a format HTML (. HTML)
- Retain the original layout, format, and hyperlinks
- Supports most popular browsers, like IE, Firefox, Safari and Opera.
- Ability to determine the quality of images in the exported HTML files
• Convert PDF files into text format (. TXT)
- Extract all text content from PDF files
• Support format PDF 1,0-1,7
• Convert the whole PDF document, or only a specific range of pages (all from - to, individual pages).
• Batch mode conversion.
• AnyBizSoft PDF Converter can also convert encrypted PDF files that are protected from printing, editing and copying.
• For PDF files with password for opening, you must enter the password in the popup window, and then start the conversion.
• A pleasant and friendly interface.
[-] The following 5 users Like paladin's post:5 users Like paladin's post
  • Dell_Brett, simanta, kminguy, engrezi, i_kabir
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
09-19-2010, 09:35 AM (This post was last modified: 09-19-2010, 10:24 AM by kowheng.)
mirror link
[-] The following 2 users Like ssobhan's post:2 users Like ssobhan's post
  • masafi_15, 3fan
  STDU Converter 2.0.61.0 [DJVU to PDF Converter] Dell_Brett 0 4,897 12-20-2010, 07:45 AM
Last Post: Dell_Brett
