Civil Engineering Association eBooks Journals, Papers and Presentations COMM. ON THE GUIDE FOR BUCKLING AND ULTIMATE STRENGTH ASSESSMENT FOR OFFSHORE STRUCT
 yanburak
User ID: 27551
Threads: 74
Likes: 821 in 94 posts
Given Likes: 421
09-19-2010, 06:13 AM (This post was last modified: 09-19-2010, 09:44 AM by Dell_Brett.)
COMMENTARY ON THE GUIDE FOR BUCKLING AND ULTIMATE STRENGTH ASSESSMENT FOR OFFSHORE STRUCTURES
[Image: 14646135033716786537.jpg]
This Commentary provides the fundamental principles and technical background, including sources and additional details, for the ABS Guide for Buckling and Ultimate Strength Assessment for Offshore Structures, April 2004, which is referred to herein as β€œthe ABS Buckling Guide”. The Commentary presents supplementary information to better explain the basis and intent of the criteria that are used in the ABS Buckling Guide. The accuracy for determining buckling and the ultimate strength predictions obtained from the application of the ABS Buckling Guide is established by the comparison of its results against a very extensive database of test results assembled by ABS and also from the results of nonlinear finite element analysis. Results obtained using the criteria in the ABS Buckling Guide are also compared against existing recognized offshore standards, such as the ABS MODU Rules, API RP 2A WSD, API Bulletins 2U and 2V, DnV CN30.1, and AISC LRFD [references 1, 3, 5, 6, 7, 30].
138 pages - 3Mb
[-] The following 6 users Like yanburak's post:6 users Like yanburak's post
  β€’ kowheng, jcbv, ssobhan, Dell_Brett, ladjin, draluka
  Lateral-torsional buckling capacity assessment of web opening steel girders by artifi ssobhan 0 3,871 08-02-2014, 10:21 AM
Last Post: ssobhan
  Consistent equivalent geometric imperfections for the numerical buckling strength ver asim99 0 3,740 04-02-2013, 11:35 PM
  Elastic Buckling Strength of Gusset Plate Connections ynopum 0 4,135 03-09-2012, 10:54 AM
Last Post: ynopum
  ASCE JOURNAL OF STRUCT. ENG. VOL 128 radespino 0 3,953 09-11-2010, 03:41 AM
Last Post: radespino
