Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive Stephens' C# Programming with Visual Studio 2010 24-Hour Trainer
 igor1234
User ID: 17154
Threads: 38
Likes: 677 in 124 posts
Given Likes: 678
09-06-2010, 11:30 AM
# Paperback: 552 pages
# Publisher: Wrox; Pap/Dvdr edition (May 17, 2010)
# ISBN-10: 0470596902
# ISBN-13: 978-0470596906
[Image: 86307520331807495870.jpg]
A unique book-and-DVD package from preeminent programming instructor Rod Stephens
Visual C# has become a leading programming language, resulting in greater career opportunities for Visual C# programmers. This Wrox guide literally shows novice programmers how to program in C# with Microsoft Visual Studio, using both written and visual instruction.
Easy-to-follow lessons reinforced with step-by-step instructions, screencasts, and supplemental exercises make it easy to master Visual C# programming regardless of your learning style. Each lesson begins with a discussion of a concept or technique and proceeds through step-by-step directions for using the technique Visual C# has surpassed Visual Basic as the most popular programming language
* This book-and-DVD package provides an introduction to Visual C# programming, with screencasts on the DVD to support each lesson in the book
* Each lesson includes a "Try It" section with exercises for developing a programming solution, goals for the exercise, and pointers about handling more complex issues
* DVD shows how the author works through each lesson in the book
Stephens 24-Hour Trainer: C# Programming with Visual Studio 2010 teaches Visual C# in the clear, compelling style for which Rod Stephens is famous.
Thanks
[-] The following 1 user Likes igor1234's post:1 user Likes igor1234's post
  • mishanya
 ARRAGON
User ID: 18968
Likes: 12 in 2 posts
Given Likes: 70
09-06-2010, 02:42 PM
Hello Igor
i belive you want to learn visual c sharp , what you are requesting for a very good book for introductory level . you may want to go through this dvd as well .
let me know how it is ?
with regards
ARRAGON
AppDev Learning To Program Using Visual C Sharp C# 2008
Quote:
In this course, you’ll learn to use Visual Studio 2008 to explore the Visual C# language. The course starts with a quick overview of the .NET platform, examining assemblies, Microsoft Intermediate Language, Visual Studio profiles, XML comments, IntelliSense, and debugging. From there, you’ll learn all the language features that you must internalize in order to create full-featured Web or Windows applications that make best use of the .NET platform. You’ll learn about data types, variables, and operators, along with all the important flow control structures. You’ll work through several examples demonstrating the power of the .NET Framework, and dig into creating and consuming your own classes and objects. The course moves on to working with data structures, such as arrays and collection classes, before finishing up with discussions of generics, handling exceptions and working with delegates and events. The course concludes by introducing the new LINQ-oriented features added to the .NET Framework 3.5, including anonymous types, lambda expressions, and more. By the end of this course, you will understand the important basic concepts that will allow you to start creating the applications you need.
In this course, you will learn how to…
* Build and debug applications using Visual Studio 2008.
* Create and use variables, operators, and data types.
* Find and use the classes you need within the .NET Framework.
* Manage flow control within your code, branching and looping as needed.
* Create and consume classes and objects.
* Add and consume properties and methods in your classes.
* Make use of .NET's object-oriented features, such as overloading, inheritance and interfaces.
* Store, retrieve, and manipulate multiple values using arrays.
* Work with .NET generics.
* Make best use of the .NET Framework's support for collection classes.
* Handle exceptions in your code.
* Create and use delegates, and understand how they relate to events.
* Use anonymous types, lambda expressions, extension methods, object initializers, and implicit type declaration.
Prerequisites: This course assumes that students have some programming background. No specific experience with Visual Studio 2008 or the .NET Framework is required. As with any such course, the more experience you bring to the course, the more you’ll get out of it. This course moves quickly through a broad range of programming topics, but it does not require any prior .NET skills.
Download: RS links | No Pass | Enjoy!
[-] The following 3 users Like ARRAGON's post:3 users Like ARRAGON's post
  • muhendist, jcbv, mishanya
 igor1234
User ID: 17154
Threads: 38
Given Likes: 678
09-07-2010, 06:43 AM
ARRAGON,
Actually I need the specified book+DVD.
It is worth to have AppDev Tutorial, Thanks.
If someone have the Stephens' book, please share it.
  TECHNICAL CALCULATION AND ESTIMATOR'S MAN-HOUR MANUAL superandy 4 4,634 05-30-2011, 02:41 PM
Last Post: superandy
  Stephens' C# Programming with Visual Studio 2010 24-Hour Trainer igor1234 0 1,702 08-11-2010, 10:10 AM
Last Post: igor1234
