Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Theoretical Effective Length Factors for Cross-Braced Solid Round Diagonals
 yanburak
User ID: 27551
Threads: 74
Likes: 821 in 94 posts
Given Likes: 421
09-04-2010, 09:03 AM
[Image: 58599022860510155150.jpg]
The objective of the investigation is to determine theoretically the effective
length factors of cross-braced solid round diagonals in all-welded steel
communication towers. Three beam-column models with different boundary
conditions (pinned, elastically restraked, and fixed) were investigated and it was
show that a beam-column with elastic restraints at ends and at cross-brace
location is the most accurate. However, for design purposes, when the ratio of
the diameter of the leg to the diameter of the diagonal exceeds three, beam-column
mode1 with fixed ends and elastic restraint at cross-brace location is
satisfactory. The theoretical results were compared with results of tests on 26
specimens.
[-] The following 5 users Like yanburak's post:5 users Like yanburak's post
  β€’ kowheng, jcbv, blaze, Dell_Brett, oanm2000
  RANSFER LENGTH, DEVELOPMENT LENGTH, FLEXURAL STRENGTH, AND PRESTRESS LOSS EVALUATION Haseeb Jamal 1 2,213 01-29-2012, 08:14 AM
Last Post: jokerβ„’
