How can link Revit to MS Excel, I need your helps!
Thank in advance,
Thank in advance,
For which purpose you want to link revit and excel...
Try to download extension4revit....its works for grid generation, column,beam directly from excel sheet...just need to enter numerical data in excel Moderator Notes: Please use "NEW REPLY" button next time. You may be warned for spamming if you kept replying with "REPLY" button (quoted text without good reason).
09-04-2010, 04:33 PM
You can use "Visual Studio Tools for Applications" to connect Revit and Excell.
Both programs are programmable using Visual Studio. Look here: Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 and here: Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈 Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈
09-13-2010, 02:03 AM
You can use built-in VBA
