Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Multiple support response spectrum analysis
 vttrlc
User ID: 23265
Threads: 4
Likes: 58 in 7 posts
Given Likes: 3
09-03-2010, 08:04 AM
Multiple support response spectrum analysis of bridges
A comprehensive investigation of the Multiple Support Response Spectrum (MSRS) method for seismic analysis of bridges and other multiply supported structures is presented. The method accurately accounts for the spatial variability of ground motions, including the effects of incoherence, wave passage, and spatially varying site response. The structural response is obtained in terms of response spectra and peak displacements at individual support degrees of freedom, and a coherency function that characterizes the three spatial variability effects. Special attention is given to the effect of site response arising from variation in the soil conditions at different supports of the structure. Through extensive comparisons with time history analysis, the validity of the MSRS rule and the site response component of the coherency function are established. Methods for estimating the site frequency response function, needed in the coherency model, are developed and examined. These models and rules are implemented in the MSRS code for application to three-dimensional, multiply supported structures. Using the MSRS code, extensive parametric studies are performed for two example bridge structures.
[-] The following 12 users Like vttrlc's post:12 users Like vttrlc's post
  â€¢ kowheng, jcoronellr, oanm2000, Dell_Brett, orambo, yantonegr, essenza, mecheil.edwar, rezart, zrilek, zainseiya, atram
Threads: 57
03-23-2011, 10:17 AM (This post was last modified: 12-10-2011, 02:58 AM by kowheng.)
[Image: 00837892006016047691.jpg]
PDF|RAR 7.37|6.60 MB
[-] The following 10 users Like kowheng's post:10 users Like kowheng's post
  â€¢ rezart, zrilek, seriousboy, blaze, faros3000, vardan, oanm2000, malc, zainseiya, atram
  Seismic Ground Response Analysis cace-01 1 2,212 02-20-2015, 04:12 PM
Last Post: Veggeta
  Lecture Notes: Nonlinear Earthquake Response Analysis of Reinforced Concrete Building RyanRS 0 1,934 10-04-2014, 04:04 PM
Last Post: RyanRS
  Response Spectrum Method in Seismic Analysis and Design of Structures parhyang 4 5,644 06-18-2014, 06:01 AM
Last Post: bigone
  A response spectrum method for random vibrations preceptor 2 3,556 06-24-2012, 07:40 AM
  Response History Analysis of Structures with Seismic Isolation and Energy Dissipation andre85 0 2,027 02-02-2012, 07:13 AM
Last Post: andre85
