Civil Engineering Association Software Software Product Bentley Products RAM Elelments v8i (SELECTseries 2) 10.5.0 Build 122
Threads: 1,128
07-24-2010, 03:26 PM
This program provides unequaled flexibility for the design and analysis of different types of 2D or 3D structures containing linear members and shell elements.
The types of analysis available are: First order (Linear Analysis), Second order (P-Delta Analysis) and Dynamic (Seismic Analysis).
In addition, RAM Elements is also capable of designing hot-rolled or cold-formed steel members, wood (sawn lumber and glulam) and reinforced concrete members using the AISC 360-05 ASD, AISC 360-05 LRFD , BS 5950-00, AISI 01 ASD, AISI 01 LRFD, AS4100-98, NDS 05 ASD, ASD 05 LRFD, ACI 318-99, ACI 318-05 y BS8110-97 codes respectively. The program includes special modules for designing spread footings, combined footings, reinforced concrete columns, retaining walls, concrete walls, tilt-up walls, masonry walls, continuous beams and trusses. Additionally RAM Elements has links with RAM Connection, a revolutionary tool that allows the fast design of steel connections inside or outside RAM Elements, STAAD.Pro, the RAM Structural System and ProSteel (SDNF).
The previous medicine of struceng still working
[Image: 51436925580992551490.gif]
[Image: 50593348794835379057.gif]
[-] The following 45 users Like BennyP's post:45 users Like BennyP's post
  • jacky899, Nilupa, cordoba123, sonidero, maad59, hzaheer, jjmtz, panchotevi, Dell_Brett, tomdavar, ali akbar, mulham lee, ruaumoko, Galileo, redtony, kowheng, haze, jorge64, cybermad, oanm2000, ranasanga, vir_lao, aema, akseley, vitacote, tremonti, valinhas, Octavio, zrilek, spat, mickaddy, oreslaw, javish, bigone, planeti_x, yutt, Parmenides, simanta, adams, arceon, olgabehe, xuanxo, subin91, granjero_mx, TAFATNEB
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42492
07-25-2010, 10:05 AM
For "medicine" refer to post #2 @:
Dell Brett
[-] The following 19 users Like Dell_Brett's post:19 users Like Dell_Brett's post
  • haze, sonidero, oanm2000, ranasanga, aema, tremonti, valinhas, zrilek, spat, kerenski_t, mickaddy, oreslaw, bigone, malc, Octavio, adams, ting tsai huang, mgdario, xuanxo
 l_namali
User ID: 2969
Threads: 11
Likes: 498 in 47 posts
Given Likes: 130
07-17-2011, 10:27 AM (This post was last modified: 07-17-2011, 10:49 AM by Dell_Brett.)
MIRROR LINKS:
cheers
[-] The following 14 users Like l_namali's post:14 users Like l_namali's post
  • Dell_Brett, jcbv, llbb, malc, haze, zrilek, apiratkan, ha893459, bigone, adams, valinhas, taifur, oanm2000, narendra
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,246 in 938 posts
Given Likes: 2428
08-16-2011, 05:24 PM
HOTFILE MIRROR
No limits to creativity
[-] The following 5 users Like joker™'s post:5 users Like joker™'s post
  • Dell_Brett, zrilek, arceon, xuanxo, oanm2000
  STAAD.Pro V8i SELECTseries 5, build 20.07.10.64 coxxxyboy 9 28,329 07-07-2023, 02:35 AM
Last Post: Arigato
