Civil Engineering Association eBooks Journals, Papers and Presentations ACI Structural Journal/July-August 2010
 Badis
Senior Member
User ID: 16671
Threads: 53
Likes: 2,308 in 169 posts
Given Likes: 221
07-01-2010, 07:17 AM
[Image: 13195966304770021724.jpg]
VOL. 107, NO. 04, JULY-AUGUEST 2010
107-s37 Performance of Retrofit Highway Barriers with Mechanical Anchors
107-s38 Nonlinear Analysis of Cross Sections under Axial Load and Biaxial Bending
107-s39 Analytical Modeling of Medium-Rise Reinforced Concrete Shear Walls
107-s40 Smeared Rotating Crack Model for Reinforced Concrete Membrane Elements
107-s41 Shear-Transfer Strength of Reinforced Concrete
107-s42 Seismic Design of Reinforced Concrete Bridge Columns at Subfreezing Temperatures
107-s43 Strengthening of Flat Slabs Against Punching Shear Using Post-Installed Shear Reinforcement
107-s44 Shear Behavior of Externally Prestressed Beams with Carbon Fiber-Reinforced Polymer Tendons
107-s45 Ultimate Strength of Reinforced Concrete Beams Retrofitted with Hybrid Bonded Fiber-Reinforced Polymer
107-s46 Transverse Resistance of Masonry Infills
107-s47 Punching Shear Behavior of Two-Way Slabs Reinforced with High-Strength Steel
107-s48 Compression Splices in Confined Concrete of 40 and 60 MPa (5800 and 8700 psi) Compressive Strengths
d107-s04 Five Discussions from the September/October 2009 ACI Structural Journal
[Image: 75883136686205779278.jpg]
[-] The following 13 users Like Badis's post:13 users Like Badis's post
  â€¢ Dell_Brett, Grunf, kowheng, tarado, concreteok, cardinal85, oanm2000, yucapareja, juangpulidoc, fer962933, asiac, YeiYei, Umer.Aleem
  ACI Structural Journal Collection essenza 23 61,315 04-21-2016, 07:41 PM
Last Post: bridgeengineer
  Earthquake Spectra August 2010 Volume 26 Issue 3 igor1234 1 7,271 10-07-2014, 10:23 AM
Last Post: rossinando
  Journal of Structural Engineering - Papers lisine 10 19,902 06-07-2013, 06:41 AM
  Journal Earthquake Engineering & Structural Dynamics - Papers lisine 5 11,356 02-12-2013, 10:56 AM
  JOURNAL OF STRUCTURAL ENGINEERING © ASCE / JANUARY - JUNE 2009 cve_jule 6 15,451 01-23-2013, 05:28 PM
Last Post: fer962933
  Journal: Earthquake Engineering & Structural Dynamics faros3000 6 12,925 11-05-2012, 12:50 PM
Last Post: mybest
  Journal Structural and Multidisciplinary Optimization - Requested papers lisine 0 4,338 09-03-2012, 07:52 AM
