Civil Engineering Association Various Free Discussion Ground Peak Acceleration (Agmax)
 jacs127
Senior Member
User ID: 11255
Threads: 93
Likes: 1,667 in 225 posts
Given Likes: 605
#11
06-18-2010, 03:10 PM
Dear Friends sorry very late on that but please find the link from where you can get CRISIS 2007 ... enjoy
[-] The following 2 users Like jacs127's post:2 users Like jacs127's post
  β€’ hazus, pelelo
 hazus
Tunisia
User ID: 21462
Threads: 63
Likes: 781 in 104 posts
Given Likes: 225
#12
06-18-2010, 04:46 PM
Dear Jacs127,
I downloaded the file and it's ok. But it is in spanish. can you switch the langage to english after install
  β€’
 pelelo
User ID: 17858
Threads: 89
Likes: 49 in 39 posts
Given Likes: 242
#13
06-18-2010, 08:12 PM
hello Jacs 127,
Thanks for your link.
I was wondering, can anyone please explain how to obtain the PGA for a given country? using CRISIS.
I am kind of new in the earthquake engineering area.
Thanks
  β€’
 hazus
Tunisia
User ID: 21462
Threads: 63
Given Likes: 225
#14
06-18-2010, 08:44 PM
Dear Pelelo,
you must understand the probabilistic method to calculate seismic hazard. for this you need to understand what is
- seismic zone (surface or fault)
- attenuation laws, wich are used to plot acceleration vs distance with a given magnitude
- gutenberg richter curves to describe number of earthquake with a given magnitude by years
after that, cornell method can be used to calculate pga which is the maximum acceleration generated at a site by all seismic sources.
all those steps are given with scientific background is the program help.
I d'ont know if crisis 2007 uses cornell method or not but seisriskIII do.
i'll try to make example with it and will help. I think it take shp files (files by gis systems)
just a confirmation: for this version, After installation, I found it in english except for the tsunami model help wich is wrote in mexican.
regards
[-] The following 1 user Likes hazus's post:1 user Likes hazus's post
  β€’ pelelo
 jacs127
Senior Member
User ID: 11255
Threads: 93
Given Likes: 605
#15
06-19-2010, 03:21 AM
(06-18-2010, 04:46 PM)hazus Wrote: Dear Jacs127,
Yes hazus you can and infact it operates in English ... in my workstations... still if you have difficulty then let me know...
[-] The following 1 user Likes jacs127's post:1 user Likes jacs127's post
  β€’ pelelo
 chigozie
User ID: 5921
Threads: 6
Likes: 657 in 257 posts
Given Likes: 1548
#16
06-19-2010, 11:20 AM
Since the project your firm is working on is located in a place, for some reason that doesn’t have a structural or seismic code, one of your best options will be to simulate the likely seismcity of the area (using the software suggested) or accelerogram. This will give you a reasonable data for the calculation of the PGA, on the condition that you have detailed data of the site's characteristics (ie the geological, topographical characteristics, it's distance from fault lines etc).
You needed the Fo and Ss. as to be able to modify the generic PGA as to convert it to your site condition. This is only necessary when you lifted the PGA from a generic seismic map (which is not your case as you said that such a map is not available). As such, you could get your PGA directly from the simulation.
Since you can obtain Ss and or any other information from any of the 14 spectral maps provided by IBC, you could adopt these as long as your soil (site) exhibits same/similar characteristics as the particular soil as given in the IBC. So, in the absence of the necessary data, try to get as much as many data possible (independently; on-site) and adopt those that you can not lay hands on, putting in mind the fact that you have to be conservative in your esimates, since you are piecing together the datas.
Buona fortuna.
Teddy
[-] The following 5 users Like chigozie's post:5 users Like chigozie's post
  β€’ Grunf, Apache, Dell_Brett, hazus, pelelo
Pages (2): « Previous 1 2
