Civil Engineering Association Software Software Product Autodesk Products Revit extensions for Revit structure 2010
 mouhandiss
User ID: 187
Threads: 2
Likes: 49 in 2 posts
Given Likes: 0
04-24-2009, 07:47 PM
hi all
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
:heart::heart::heart:
[-] The following 38 users Like mouhandiss's post:38 users Like mouhandiss's post
  โ€ข oanm2000, oanm2000, kamran, kamran, bubieng, bubieng, Dell_Brett, Dell_Brett, paulocs, paulocs, Uginjo, Uginjo, hsccindia, hsccindia, zrilek, zrilek, hvcompxd05, hvcompxd05, timosiโ„ข, timosiโ„ข, essam2109, essam2109, samarad, samarad, subin91, subin91, cristi, cristi, pap2007, pap2007, nuttapolk, iamnowtheone, cgedmundo, u4406014, jinualex, stigtg, mastermind, erthqkengnrโ„ข
 timosiโ„ข
User ID: 3890
Threads: 138
Likes: 5,532 in 394 posts
Given Likes: 1812
09-19-2009, 12:47 PM (This post was last modified: 09-19-2009, 12:47 PM by timosiโ„ข.)
(09-19-2009, 11:59 AM)hvcompxd05 Wrote: Hi mouhandiss,thank you so much for your link!
but,do you have mediafire link?
hvcompxd05
You can't download from rapidshare. I can understand. Lucky I can help you. Try download this those links & enjoy:
Second mirror link for our forums:
regard
timosi
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 16 users Like timosiโ„ข's post:16 users Like timosiโ„ข's post
  โ€ข essam2109, essam2109, hvcompxd05, hvcompxd05, zrilek, zrilek, levanduy, levanduy, civil, civil, lonelyboy, lonelyboy, DamirDz, u4406014, relu59, jinualex
 kamran
Senior Member
User ID: 91
Likes: 1,777 in 176 posts
Given Likes: 1299
10-06-2009, 06:31 PM
(09-30-2009, 09:22 AM)Dell Brett Wrote:
Autodesk Revit Structure 2010 Extensions Collection
[Image: 0e0gqlieul4odkhi3y08.jpg]
WinApp | Autodesk Revit Structure 2010 Extensions Collection | 542.33 Mb
The Revit Extensions for Revit Structure 2010 delivers a full range of benefits to enhance and leverage Autodeskยฎ Revitยฎ Structure 2010. Users of these extensions will benefit from their ease of use, enabling them to be more productive and agile while working on projects and responding to customer requests.
Enhancements in Revit Extensions for Revit Structure 2010 include:
Robot Structural Analysis
Composite Design, Load Takedown, Integration with Robot Structural Analysis, Reinforcement Design
Simulation Beams, Conceptual Form Simulation, Frames, Trusses, Slabs
AutoCAD Structural Detailing
Integration with Steel Module, Reinforcement Drawings, Integration with Formwork Drawings Module
Steel Connections (Knots)
Beam to column - end-plate, Column base
Import / Export (Import / Export)
CIS / 2 Export, CIS / 2 Import
Reinforcement (Reinforcement)
Automatic Reinforcement Generation, Parapets, Piles, Retaining Walls, Slab Corners, Wall Corners, Walls, Beams, Columns, Spread Footings, Continuous Footings, Slab Openings, Pile Caps
Modeling (Modeling)
Bridge, Excel Based Model Generation, Grids Generator
Miscellaneous (Misc)
Content Generator, Text Generator, Elements Positioning, Freeze Drawings, Compare Models
Centered on the structural analysis, modeling, reinforcement of concrete, interoperability, and documentation design, Extensions for Revit Structure 2010 Revit, an extensive range of tools, users can start to take advantage of today!
Download Links:
(10-04-2009, 06:35 AM)leithowsky Wrote: Megaupload download links
Kamran via HP :)
[-] The following 8 users Like kamran's post:8 users Like kamran's post
  โ€ข subin91, subin91, zrilek, zrilek, relu59, veafrian, avscorreia, wannaspk
  Autodesk Revit 2022 poolmand 9 12,355 11-16-2021, 08:14 AM
  Revit 2021 zrilek 3 7,905 05-18-2021, 04:58 AM
Last Post: zrilek
  Autodesk Revit LT 2021.1 (x64) Multilanguage BennyP 1 5,276 02-22-2021, 03:40 PM
  Revit - Site Designer extension 2020 oonan 0 6,628 12-26-2020, 11:31 PM
Last Post: oonan
  REVIT 2020 (x64) feron 2 10,481 04-22-2019, 08:01 PM
  Autodesk Revit 2019 and Revit LT 2019 BennyP 7 15,912 02-12-2019, 02:02 PM
  AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 11,764 04-21-2018, 09:51 PM
Last Post: jokerโ„ข
