AutoCAD Map 3D
AutoCAD® Map 3D software enables engineers, planners, mapping technicians, surveyors, and GIS professionals to directly access, edit, visualize, and analyze a broad variety of CAD and spatial data in a familiar AutoCAD® software environment.
AutoCAD Map 3D mapping software is one of the leading engineering platforms for creating and managing spatial data and bridges the gap between CAD and GIS. AutoCAD Map 3D makes it possible for engineering and GIS professionals to work with the same data, and helps you integrate geospatial functions in a single environment for more efficient workflows.
