Civil Engineering Association Software Software Product Autodesk Products Autodesk Robot Structural Analysis Professional 2011 SP
Threads: 1,118
05-10-2010, 03:30 AM (This post was last modified: 09-29-2010, 09:28 AM by BennyP.)
Autodesk Robot Structural Analysis Professional 2011 SP1
Installation
The ESOP for Robot option group, previously unavailable after installation of Autodesk Robot Structural Analysis Professional 2011, has been unblocked.
A problem with Robotโ„ข Extensions Spreadsheet Calculator 2011 running only in demo mode in case Robotโ„ข Extensions Spreadsheet Calculator 2010 was previously installed has been corrected.
Software Usage
Incorrect generation of FE meshes, especially for slabs with openings, has been fixed.
Kinematic constraints are no longer applied during mesh generation when the proper check box in Job Preferences is cleared.
The starting page is no longer blocked by attempts to display corrupted file preview.
Repeated requests to participate in the Customer Involvement Program are no longer displayed.
Characters in HTML notes for non-English languages (such as Greek, Ukrainian, Chinese, and so on) now display correctly.
Problem of displaying empty places in various texts including menu options has been corrected.
Menu customization no longer results in a fatal error.
Calculating story rigidity center for buildings with non-weight walls no longer causes fatal error.
Editing of r/c drawings arrangement is no longer blocked.
Fatal error during r/c beams design for Italian settings has been corrected.
Problem of launching r/c design from Autodeskยฎ Concrete Building Structures software has been corrected.
Improper position of pins while reinforcing ACI beams has been corrected.
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
[-] The following 22 users Like BennyP's post:22 users Like BennyP's post
  โ€ข yakwetu, hsccindia, rohailiyaz, AK12, jjmtz, cve_jule, Dell_Brett, versiondemo, cristi, sasan73, Adam Smith, leonelmariana, jferrer, Struc-Con, mayabens, ke_co_doc, alkskg, yly8, parwez007, thrice10, oanm2000, Mhasan
 braunfish
Italy
User ID: 1181
Threads: 2
Likes: 7 in 3 posts
Given Likes: 14
07-21-2010, 06:01 AM (This post was last modified: 07-21-2010, 06:04 AM by kowheng.)
If it can be useful:
Service Pack 2 for Autodesk Robot Structural Analysis Professional 2011.
Download at:
[-] The following 5 users Like braunfish's post:5 users Like braunfish's post
  โ€ข oanm2000, andersen3, Dell_Brett, jacky899, Mhasan
Threads: 1,118
09-29-2010, 09:27 AM
Posted by allgui10 in the wrong place
you can download the service pack 3 from official website
  โ€ข jferrer, oanm2000
 kamran
Senior Member
User ID: 91
Likes: 1,777 in 176 posts
Given Likes: 1299
10-04-2010, 11:35 AM
Mirror of Service Pack 3 for Autodesk Robot Structural Analysis Professional 2011 & Hotfix for Robot Structural Analysis Integration with Revit Structure
Kamran via HP :)
[-] The following 3 users Like kamran's post:3 users Like kamran's post
  โ€ข oanm2000, Mhasan, kami
Threads: 1,118
10-04-2010, 04:47 PM
YES. SP3 is cumulative.
  โ€ข ruwan75, oanm2000
 allagui10
User ID: 962
Threads: 7
Likes: 521 in 102 posts
Given Likes: 244
10-22-2010, 03:59 PM
Hi,
Update or SP4
autodesk robot structural analysis professional 2011
This update may be applied to any licensed copy of Autodesk Robot Structural Analysis Professional 2011 software installed as a stand-alone product or as part of a suite, with or without installed updates 1, 2, or 3.
This update includes Update 1, 2, and 3. You do not need to install either of them prior to installing Update 4.
autodesk robot structural analysis 2011
This update may be applied to any licensed copy of Autodesk Robot Structural Analysis 2011 software installed as a stand-alone product or as part of a suite, with or without installed updates 1, 2, or 3.
Autodesk Robot Structural Analysis Professional 2011 (x64)
This update may be applied to any licensed copy of Autodesk Robot Structural Analysis Professional 2011 64-bit software installed as a stand-alone product or as part of a suite.
[-] The following 4 users Like allagui10's post:4 users Like allagui10's post
  โ€ข Dell_Brett, oanm2000, jacky899, rkce
 allagui10
User ID: 962
Threads: 7
Given Likes: 244
12-25-2010, 11:43 AM
Hi,
SP5
This service pack includes packs 1, 2, 3, and 4. You do not need to install any of them prior to installing Service Pack 5.
Primary Issues Resolved by Service Pack 5
Model Definition and Analysis
concrete Design
beam
Steel Design
Steel Connections
details are given in readme text
[-] The following 7 users Like allagui10's post:7 users Like allagui10's post
  โ€ข Dell_Brett, jcbv, oanm2000, hzaheer, rkce, stigtg, kami
 jcbv
User ID: 19792
Threads: 30
Likes: 962 in 84 posts
Given Likes: 7825
12-26-2010, 02:57 PM
Hi everybody,
If you are using the pro edition or x64 edition of the program, the right links for SP5 are:
However, more informations are here:
[-] The following 8 users Like jcbv's post:8 users Like jcbv's post
  โ€ข rezart, Dell_Brett, oanm2000, boyet, rkce, wripes, ramla2002, abalcu
  Autodesk Robot 2026 rami1976 0 3,482 05-27-2025, 09:10 PM
  Autodesk Robot Structural Analysis Professional 2024 (x64) Multilanguage TAFATNEB 1 12,734 04-16-2023, 09:52 AM
  Autodesk Inventor Professional 2020 BennyP 2 7,852 12-03-2021, 05:56 AM
Last Post: TheMachinist
  Autodesk Robot Structural analysis Professional 2021 rami1976 4 10,495 04-18-2020, 11:52 PM
Last Post: rigid_joint
  Autodesk Robot 2020 structural analysis professional rami1976 2 7,671 04-26-2019, 03:43 AM
  Autodesk Robot Structural Analysis Professional 2019 jokerโ„ข 2 8,176 09-07-2018, 07:49 PM
  Autodesk Robot Structural Analysis Professional 2018 rami1976 4 12,014 10-11-2017, 07:47 PM
