Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem RSA (robot) steel connection export
 rohailiyaz
User ID: 925
Threads: 104
Likes: 1,152 in 117 posts
Given Likes: 733
04-30-2010, 08:12 AM
Here is a robot file of steel frame
I have analysed and design members and connections but when export it to revit only columns and beam export not the connections.
can anyone guide me how to export connections to revit
Rohail
  â€¢
 karhell
User ID: 23192
Likes: 0 in 0 posts
Given Likes: 1
05-29-2010, 09:47 PM
Hello,
I need help, i dont get to assign a steel connection into a node in robot. Please could you help me.
  â€¢
 rohailiyaz
User ID: 925
Threads: 104
Given Likes: 733
05-30-2010, 05:08 PM
kindly provide ur model/file and explain what problems ur facing so that i can help you out
  â€¢
 allagui10
User ID: 962
Threads: 7
Likes: 521 in 102 posts
Given Likes: 244
06-20-2010, 10:31 AM (This post was last modified: 06-20-2010, 11:53 AM by kowheng.)
save the model in robot
run asd steel
use robot link and fullfill the correct instructtions(create a link+ import model from robot +transfer connections)
  â€¢
