Civil Engineering Association Software Software Product Autodesk Products Autodesk AutoCAD Revit Structure Suite 2010 x86 DVD
Threads: 150
Given Likes: 28542
04-20-2009, 05:59 PM (This post was last modified: 08-26-2009, 02:45 PM by cod-X.)
Autodesk AutoCAD Revit Structure Suite 2010 x86 DVD-NoPE | 2.24 GB
Design and shape the world around you with the powerful, flexible features found in AutoCAD design and documentation software, one of the worldร†s leading 2D and 3D CAD tools. Speed documentation, share ideas seamlessly, and explore ideas more intuitively in 3D. With thousands of available add-ons, AutoCAD software provides the ultimate in flexibility, customized for your specific needs. It's time to take design further. It's time for AutoCAD.
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
.jpeg   000c71b8_medium.jpeg (Size: 16.66 KB / Downloads: 157)
[-] The following 15 users Like oanm2000's post:15 users Like oanm2000's post
  โ€ข Dell_Brett, Dell_Brett, BUZZ3S, BUZZ3S, kamran, kamran, zrilek, zrilek, zbizafar, zbizafar, ChisTeam, ChisTeam, u4406014, u4406014, DamaD
Threads: 1,118
04-22-2009, 07:29 AM
Someone realy have Autodesk AutoCAD Revit Structure Suite 2010 ?
This link jump from site to site (I found it in few different sites) but this is Autocad Structural Detailing.
May be a good software but not Revit.
  โ€ข
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Likes: 21,198 in 2,356 posts
Given Likes: 4260
04-22-2009, 10:16 AM (This post was last modified: 04-22-2009, 10:31 AM by Administrator.)
try this:
or on 2.27GB File:
or download from emule (torrent)
[-] The following 6 users Like Administrator 's post:6 users Like Administrator 's post
  โ€ข oanm2000, oanm2000, kamran, kamran, Yasir, u4406014
 kamran
Senior Member
User ID: 91
Likes: 1,777 in 176 posts
Given Likes: 1299
04-25-2009, 06:41 PM (This post was last modified: 04-25-2009, 06:42 PM by kamran.)
hi , Revit Structure 2010 trial
all download links are 6.2 GB
you can download Templates & Libraries from this link :
OR
Notes
* After downloading the following files, you may need to update the file locations manually (on the Application Menu, click the Options button, press the File Locations tab to review and modify the location of your files). For Microsoftยฎ Windowsยฎ XP, the default location for templates and family content is C:\Documents and Settings\All Users\Application Data\Autodesk\RST 2010. For Microsoftยฎ Windows Vistaยฎ, the default location for templates and family content is C:\ProgramData\Autodesk\RST 2010.
* In an office with multiple computers running Autodeskยฎ Revitยฎ Structure software, you may want to install these files to a location on your network.
* To open these .cab files and extract the content, use WinZip 7 or higher.
download revit structure without Templates & Libraries
Notes
* The executable file contains both 32 and 64-Bit versions of Autodesk Revit Structure 2010.
* The executable file can be applied to both the standalone and Suite versions of Autodesk Revit Structure 2010.
* Downloads are applicable to licenses under subscription or for trial or demo licenses for non-subscription users, worldwide.
* Files saved in new releases of this product are not compatible with previous releases. However, files saved in the same release are compatible across different build numbers.
* Microsoftยฎ Internet Explorerยฎ 6 (SP1 or later) is required.
* For problems downloading or installing Autodesk Revit Structure 2010 and for general information or questions, contact Autodesk Product Support (Autodeskยฎ Subscription login required
Kamran via HP :)
[-] The following 11 users Like kamran's post:11 users Like kamran's post
  โ€ข Administrator , Administrator , oanm2000, oanm2000, Dell_Brett, Dell_Brett, civil, civil, zrilek, zrilek, blackjack
Threads: 1,118
07-17-2009, 02:17 AM
(07-17-2009, 12:30 AM)qazplm Wrote:
(07-15-2009, 03:55 AM)rohailiyaz Wrote: during installation am getting this error
1: 5 2: failed to load FNP_ACT-Installer.dll 3:193
can any one please guide me over this problem........
i have the same problem!
somebody have a solution for this?
Fnp_act_installer.dll errors are often critical system errors caused by corrupt and missing registry data. This error should be fixed immediately to prevent further damage to the Windows file system.
Fnp_act_installer.dll error symptoms can include slow PC performance, program crashes, system freezes, startup/shutdown problems, and file errors. Risks that can result from not repairing your computer include blue screens, file corruption, and hardware failure.
Fixing Fnp_act_installer.dll is easy. Download and install a registry check tool that will analyze your registry for missing, obsolete, and corrupt entries resulting from failed installations, incomplete un-installations, disabled drivers, and spyware applications.
  โ€ข
 Arigato
Ireland
User ID: 740
Threads: 29
Likes: 893 in 88 posts
Given Likes: 277
07-19-2009, 07:03 AM (This post was last modified: 07-19-2009, 10:54 AM by kamran.)
for x86/ Windows - 32bit
for Windows-64bit
Installation:
-Unpack, burn & install.
-Check Crack/Install.txt on DVD
Links existing as of 19 July 2009.
You can copy and paste the links in the
to check if it is still active - 'File to Load'.
Hey, don't forget to say THANKS by pressing the button !
[-] The following 32 users Like Arigato's post:32 users Like Arigato's post
  โ€ข oanm2000, oanm2000, kamran, kamran, civil, civil, zrilek, zrilek, Panjack39, Panjack39, claudius, claudius, fashion, fashion, zbizafar, zbizafar, Parana34, Parana34, JOERFERO, JOERFERO, u4406014, u4406014, mmat, mmat, ChisTeam, nuttapolk, engiman27, lenanserafin, goober, adilch, gre130, mahfuzbangla
 timosiโ„ข
User ID: 3890
Threads: 138
Likes: 5,532 in 394 posts
Given Likes: 1812
08-25-2009, 01:17 PM
(08-25-2009, 08:27 AM)zbizafar Wrote: Can some one post the Crack for Revit Structure 2010 Only.
Thanks and regards,
You don't need using cra**ck, here is keygen, it work 100%, I tested.
Regard
timosi.
[-] The following 8 users Like timosiโ„ข's post:8 users Like timosiโ„ข's post
  โ€ข zrilek, zrilek, zbizafar, zbizafar, JOERFERO, JOERFERO, mowafi, u4406014
  AutoRebar for Autodesk AutoCAD poolmand 1 12,608 08-18-2025, 09:58 AM
  Autodesk 2010 Products Keygen cod-X 6 22,874 03-12-2025, 09:49 AM
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 6,132 12-02-2024, 01:09 PM
  Autodesk AutoCAD Plant 3D 2022 (x64) Pre-Cracked BennyP 1 10,732 10-27-2023, 04:10 PM
Last Post: Dalvisahi014
  Autodesk AutoCAD 2022 (x64) BennyP 5 13,944 03-29-2022, 11:33 AM
Last Post: Arigato
  Autodesk AutoCAD Civil 3D 2022 poolmand 2 11,774 03-13-2022, 03:04 PM
Last Post: pilitro
  Autodesk Revit 2022 poolmand 9 12,344 11-16-2021, 08:14 AM
