Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem ETABS
ETABS
 JCMAS
User ID: 1019
Likes: 0 in 0 posts
Given Likes: 36
#31
05-29-2009, 11:56 PM
.pdf   29-05-2009 18-38-13.pdf (Size: 70.23 KB / Downloads: 210)
hello, Juice, Yasir,
Can you explain to me from where etabs 9,5 take values to the variables Pu, Mu and Vu to design piers elements in shear ?
regards,
jcmas
 VCHFCE
User ID: 330
Threads: 1
Likes: 8 in 2 posts
Given Likes: 31
#32
05-30-2009, 05:05 AM
They are simply design forces at top and bottom pier sections (for every floor).
They depend on defined Load Combinations used as a design Combination for Shear Wall Design - Design/Shear Wall Design/Select Design Combo.
After successfull analysis run you can view Wall Forces via Display/Show Tables/An.Res./Wall Output/Wall Forces, or via File/Print Tables/Shear Wall DEsign/Detailed Output.
After design you can view in addition Shear Wall Design Forces by Display/Show Tables/An.Res./Wall Output/Wall Design Forces.
 juice
User ID: 108
Threads: 8
Likes: 362 in 68 posts
Given Likes: 176
#33
06-03-2009, 12:19 AM
(05-29-2009, 11:56 PM)JCMAS Wrote: hello, Juice, Yasir,
regards,
jcmas
Hi jcmas, VCHFCE answered your question right. Nevertheless, please don't let ETABS do the whole design process for you. I would suggest you pick out the design loads from ETABS analysis and design your pier elements using Excel spreadsheet following the code requirements--e.g., for flexural capacity of our wall (inplane or out-of-plane) stress-strain compatibility analysis will be an interesting engineering "brain" exercise. ;)
I hope this helps.
juice
[-] The following 2 users Like juice's post:2 users Like juice's post
  • oanm2000, oanm2000
 dynamics
User ID: 1863
Threads: 2
Likes: 35 in 9 posts
Given Likes: 10
#34
07-09-2009, 02:35 AM
To all,
To answer most of your questions here, rather than exchanging ideas of which you are not so sure also if you are doing the right thing in ETABS I suggest you buy the following books from CSI everything is explained on how to model and design multi-storey building. I bought the last two books recently but I have not enough time to go through all of it yet. In production I'm still using Staadpro but start learning etabs and Sap2000 also.
http://orders.csiberkeley.com/SearchResults.asp?Cat=4
Likes: 5,368 in 651 posts
07-14-2009, 11:40 PM (This post was last modified: 07-15-2009, 09:48 AM by kamran.)
(07-14-2009, 06:39 PM)ammar.2520 Wrote: thannnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnks
Dear Ammar.2520:
I saw that today is your first day inside the Forum.
Please, if you want to say Thanks, Please, use the THANKS button, just in the below bar and next to the Reply Button. The next time that you posted anything like your first Post, you will be warned, and the second time you will be banned.
Remember: before you post any thread, please, you should read the Forum Rules first to avoid be warned.
 san333
User ID: 1119
Threads: 1
Likes: 3 in 2 posts
Given Likes: 1
#36
07-30-2009, 01:28 PM
Hi all,
How do you model transfer beam in etabs? Is it model as a shell element or only normal beam element?
The transfer structure consist of transfer beam with shear wall above the beam and column below the beam.
Can I only model the wall as a shell element and the rest (column and beam) as a beam/line element ?
Thanks.
 fashion
User ID: 3328
Threads: 15
Likes: 282 in 41 posts
Given Likes: 188
#37
08-01-2009, 07:59 AM
Which is the fundamental period of the structure in Etabs out of the, say 100, that it produces?
 promo8
User ID: 3938
Threads: 1
Likes: 50 in 5 posts
Given Likes: 1033
#38
08-04-2009, 11:08 PM
(02-05-2009, 01:18 PM)aslam Wrote: Hello everybody,
Is it possible to define & design Boundary element (size larger than regular wall) in shear wall in etabs?
Yes it is possible, you define the boundary elements as columns, of the size you want, with the same pier name as the one you used for the wall, then ETAB will take the as a shear wall with boundary elements. Hope this help you.
 essenza
User ID: 865
Threads: 54
Likes: 296 in 111 posts
Given Likes: 294
#39
08-22-2009, 12:26 AM
(08-01-2009, 07:59 AM)fashion Wrote: Which is the fundamental period of the structure in Etabs out of the, say 100, that it produces?
Fundamental period can be misleading if you don't understand what dof response you required. Many textbook said that fundamental period is the period of the first mode. Well it is correct if the structure is 2D and the response you want is in the horizontal direction which is mostly example in the books for rigid beam plane frame under lateral earthquake.
In 3D structure with rigid diaphragm with 3 floor dof then there will be 3 fundamental period and of course you have to see the mode shape in which dof it moves then the period of the mode is the fundamental period in that dof direction.
Another interesting problem is as follow. If you want to design a transfer beam or cantilever beam under vertical earthquake excitation and this beam is part of a whole large structure what is the fundamental period for vertical response spectrum? Our professors had no idea of what is the fundamental period because of the associated fundamental period only to 1st mode of all those mode periods of the structures.
I would suggest you to ask people who main works is in vibration they are the one who invent this modes and fundamental period things :D
[-] The following 2 users Like essenza's post:2 users Like essenza's post
  • fashion, fashion
 fashion
User ID: 3328
Threads: 15
Given Likes: 188
#40
08-22-2009, 10:37 AM
essenza, thanks for your answer, the main reason for my question is to know the fund. period of the structure so as to manually calculate the seismic forces (i.e. base shear) so as to hand check the results from etabs. I know i can aproximate the period with the formulas, but eigenmode analysis is kind of precise.
Users browsing this thread: 4 Guest(s)
Pages (12): « Previous 1 2 3 4 5 6 7 8 9 10 … 12 Next »
