Civil Engineering Association Civil Engineering Resource Civil Engineering Documents Engineering Spreadsheet Steel: Column Base Plate Analysis-BASEPLT9
 Ultra Zone
Senior Member
El Salvador
User ID: 195
Threads: 102
Likes: 2,410 in 167 posts
Given Likes: 2238
Points:14,054 EP
12-27-2009, 03:30 PM (This post was last modified: 12-08-2010, 03:59 AM by usman.)
BASEPLT9 - Steel Column Plate Analysis
[Image: 93276766744730633139.jpg]
I didn't make this spreadsheet and I've not tested.
Is your responsability check the calculus.
.xls   BASEPLT9 V3.7 - Steel Column Plate Analysis.xls (Size: 498 KB / Downloads: 523)
Follow the Rules
[-] The following 17 users Like Ultra Zone's post:17 users Like Ultra Zone's post
  • kowheng, Dell_Brett, Administrator , nuttapolk, Albert, wisabo, wa_sin_29, simanta, đầuto, deanz_75, Brucewils, hcardenas, zainseiya, odiclas, javish, narendra, spat
  Steel: Base Plate zbizafar 3 8,878 03-05-2024, 01:03 PM
  Steel: Base Plate Design As per AISC 9th edition knrsa 1 10,743 04-01-2021, 12:39 AM
  Steel: Pinned Base Plate Design knrsa 4 11,969 09-02-2014, 08:13 AM
Last Post: albani
  Analysis: 2D Frame Analysis with Pinned Base and Rigid Base usman 1 6,082 03-21-2014, 10:13 PM
Last Post: scorpion07
  Concrete Short Column Analysis and Design - EC BennyP 2 9,662 08-24-2013, 11:23 AM
Last Post: pezhmankhan
  Analysis: Base Plate and Shear Lug Analysis usman 2 11,385 09-18-2012, 03:53 AM
Last Post: usman
  Estimating Fire Resistance Time of Steel Beam and Column Protected by FP Insulation portal61 0 4,298 11-27-2011, 05:07 AM
Last Post: portal61
