Sap 14.1 design parameters
hello , i am really confused with the design parameters in sap 14.1
does anyone have a manual showing the definition of each parameter
thanks in advance
(11-24-2009, 01:59 AM)amareen2000 Wrote: hello , i am really confused with the design parameters in sap 14.1
thanks in advance
You have them already in your computer. By default: go to "C:\Program Files\Computers and Structures\SAP2000 14\Manuals\Design" folder and all the manuals of the design codes are there. For detailed information about these codes, try searching "Codes, Manual & Handbook" section of the forum.
[-] The following 4 users say Thank You to struceng for this post:
  • rendel_©, amareen2000, concreteok, levanduy
thank you so much i found the file
but i am having another question , is it possible to show the full detailed design for a member in sap 14.1, all i can get is just a very brief design
thanks in advance
When you right click an element after design, a screen like that will popup. By clicking "Tubular Data", you can get most detailed results that Sap2000 can give to users by default. But there are plugins that can be loaded to Sap2000 which extend/customize design outputs and also other results.
[Image: 16977805456776997048.gif]
[-] The following 1 user says Thank You to struceng for this post:
  • levanduy
hi struceng
What type of plugins are you talking ? where can we find them ?
regards
the software posted links sould be used for evaluation and testing purposes, if you like it buy it !! Always read the disclaimer and act acoordly
[-] The following 1 user says Thank You to mig21 for this post:
  • levanduy
First show design results on the screen...
Design =>Steel Frame design=>Dysplay design info=>Ok
then Put cursor over anything frame....later right click.....and ready...
regards....
[-] The following 1 user says Thank You to Veggeta for this post:
  • mig21
To Red_pool61 and Mig21: As far as I know, there is no free plugin for Etabs or Sap2000 for download. I think most populars are EC-Praxis and Cacto:
There is only a little information and sample source on the web. Examples:
And also in your computer:
You must write plugins by yourself according to your needs because there is no open forum or source for that, yet!? I wrote some in Visual Basic as shown below (one of them is for the company) and this option in Sap2000 is really very useful. You are adding your plugins from this menu.
[Image: 94249041285953732922.gif]
Regards.
[-] The following 3 users say Thank You to struceng for this post:
  • concreteok, mig21, levanduy
hi
can you explain how to load the plug in ?? I have downloaded the sample from sapwiki but i cannot instal it ? I have some experience in vb and vba and i want to start tunning my sap2000 but it is been dificult to start !
regards
  • levanduy
(11-26-2009, 10:42 AM)mig21 Wrote: hi
regards
The dll file must be registered to the system first. It is done by regsvr32.exe or if it gives error, regasm.exe. All these information for loading dll files are given at:
Once the file is registered to the system, then it can be loaded to Sap2000 with "Tools > Add/Show Plug Ins..." command. The name field will be the dll file's name without writing ".dll" at the end.
  • mig21
hi
i have already done that end it didn't work !! .... but now i am thinking ,,,, probably is because i am using a portable SAP2000 ...
i will test furder
thanks
STAAD Steel Design Parameters syedmuzaffer 4 6,243 11-07-2009, 09:15 AM
Last Post: rohailiyaz
