JEC Prog - Combined_Strap_Footing
JECProg - Combined_Strap_Footing.html
Combined Strap Footing
Robert Sasmita
[-] The following 23 users say Thank You to robertsas for this post:
  • kowheng, Dell_Brett, Octavio, jaks, nuttapolk, erimajus, goober, JIGM85, kirananvekar, deanz_75, deltalead, simanta, isurya, shaqee, adams, rendel_©, ranger, Mouh@ndiss, blaze, rkce, spat, ykhackhack, SCREAM7890
This is created according to which code?
this spread sheet gives an error when the default E is changed. Could someone plz check and confirm it?
(07-06-2010, 10:30 AM)deltalead Wrote: this spread sheet gives an error when the default E is changed. Could someone plz check and confirm it?
absolutely it gives an error
input "E" only accepts values of 200000 and 29000000 for it to work
as coded in cell E11
=IF($D$11=200000,"MPa",IF($D$11=29000000,"psi",""))
that is to trap and protect WRONG inputs!!!
Notes: my professor once told me not to rely on codes written by others.
please double check results,
RedHorse at ur service
Engineering is the professional art of applying science to the optimum conversion of natural resources to the benefit of man
[-] The following 1 user says Thank You to RedHorse for this post:
  • ykhackhack
all links dead; new link
all of JEC PROG files according to ACI here:
[-] The following 6 users say Thank You to andersen3 for this post:
  • Mohammad6299, viet2010, ting tsai huang, shadabg, bigone, malc
